float charge question
palausystem
Solar Expert Posts: 124 ✭✭✭
My newish US Battery REL 16 XC batteries want 2.17v per cell for float charge. My Sunny Island Charger which spends most of its time in float, has a 2.2v minimum. Does anyone think I should be concerned? SMA suggested I could drop the system voltage down a little to compensate...?
Off-grid 48v, 3 kw PV, Sunny Island 5048U, SunnyBoy, US Battery RE L16XC 6v, 800ah, Genset: Kohler 8.5 RES propane.
If you're cycling off-grid, I wouldn't worry about float a bit high.
Thanks, I thought it was probably close enough. .03v higher.
