Skidro
Skidro
Registered Users Posts: 1 ✭
What size cable is required to connect 2 120 amp AGM batteries together that are 1 meter apart.
What is your maximum load (continuous and sure) and charging current?
Normally, continuous load is nice at capacity/8 and surge is capacity/2.5
And charging is 5% to 25% of capacity.
AGM batteries can supply very high short term current (C*1 or even C*2).
Bill
Also, hope long is the cable to the "heavy load"? Looking for voltage drop.
Bill
... and what size fuse/breaker to "heavy load", and are the batteries in series or parallel?
