SOC meters for small systems
cptdondo
Solar Expert Posts: 105 ✭✭✭
I would like to have a SOC meter on two different systems; one is tiny; 200Ah @ 12V and the other is not much bigger at 600Ah @ 12V. What's a good system these days? A lot RVers use Trimetric but I'm not overly impressed with them as it's strictly a coulomb counter. Any others? I don't really care about monitoring all the different sources; I just want to know how much is left in the batteries.
There really isn't such a thing as a perfect, or even excellent SOC meter. There are just too many variable, and they'll all tend to drift over a period of partial charge/discharge cycles. The trimetric does have some limited ability to adjust (eg battery efficiency setting), but will still drift. Likewise with WbJr monitoring in MN classics.
IMHO, the only way to accurately measure SOC and monitor battery health in lead acid batteries is with regular SG checks.
"How much is left" is sort of a squishy number as well. If running a big load relative to bank size, the effective watt-hours available will be less than a small load, for example.Off-grid.
Oh I know. I spent a summer with a load bank, a 7Ah battery, a bunch of Hall effect sensors, and a crapload of Arduinos learning about SOC, measuring it, compensating for Peukert curves, estimating from current + voltage, I even had SG sensors and I came to the conclusion that I can pick one method that will show 10% SOC and another will show 90% SOC.
So that's why I use squishy terms, because with lead-acid there is no accurate way to really determine the charge of a battery. I'd like to get close, relatively inexpensive, and convenient.
What did you use for SG sensors?Off-grid.
These guys: https://www.sensorsmag.com/components/fiber-sensing-to-measure-battery-state-charge - the company name is at the bottom of that paper.Estragon said:What did you use for SG sensors?
The sensors were fragile and pretty reliable. I never moved forward with them as in a mobile environment AGMs make far more sense.
UPDATE: Just checked the website; the sensors are no longer available. -
VictronConnect is what I use
I use the Victron , seems to be good . Input the % efficiency and Purcurt of the battery . It then makes the required calculations . Still as previously said , it is still only a guide . Not an accurate number .
2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
IMO, the key to accurate SOC via coulomb counting is to have a daily reset to a known state. With a system that adaptively corrects out it's errors for your typical usage.
- 232 Forum & Website
