Running Dishwashers Off-grid
Oggi
Registered Users Posts: 2 ✭
Just wondering if there have been any developments with dishwasher manufacturers providing lower wattage elements in their machines? My 240v dishwasher in AU pulls about 2000watts for the element when on which usually causes my off-grid inverter to switch to mains power. If the dishwasher had a 1000w element my 4.5kw off-grid PV array could manage that a lot better. Any news on this?
I just planned ahead and got a big inverter. Dishwashers have pretty unique elements and the element is used for both heating the water and to dry. I do a quick rinse with hot water to get the dishes and machine up to temp quicker than the heater can, but it adds 5 minutes to the cycle and an extra 2 gallons of waterPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I have a newer dishwasher and it uses less than 100W without the heater element and 100WH per cycle. I added extra insulation as these cabinets have a lot of heat loss and already have 120F water close. Instead of powering the element, I use that to turn on a relay. The heating element is powered by the 60V PV array. So, the wife even has heated dry. Just have to wash dishes mid day which isn't a problem. At reduced voltage the element is about 250W. Heated dry is a 50/50 duty cycle each minute and I use a three minute timer to keep it on. Unconventional, but it works.
Thanks for the comments. I have connected the DW to hotwater so running a rinse cycle before the wash cycle is a good idea although I have been advised that most dishwashers don't have thermostats, but the rinse is still a good idea if only using the shortest wash cycle so reducing the voltage to the element sounds like the easiest way to reduce overall current draw.
"been advised that most dishwashers don't have thermostats" Perhaps you shouldn't listen to that person. Any recent one does and it will throw an error code if it can't get the temp up to 120F after a couple of wash cycles.
