Dismantling Anderson connectors.
littleharbor2
Solar Expert Posts: 2,198 ✭✭✭✭✭
Is there a way to remove the individual contacts from the medium to large sized Anderson connectors? I've never used them before and have been given a bunch of them.
IIRC, the housing bolts together in 2 pieces and the metal connectors are hydraulic crimps.Off-grid.
I don't see any accessible bolts. Does the plastic housing pop apart somehow?
There is a lip on the contact that catches on a flat spring below it. To remove the contact you need to lift the contact at the front by prying a screwdriver or flat blade between the contact and the spring below. Then push back the contact with a flat blade or pull from the rear. Here is a video for a SB50 but the big ones are essentially the same:littleharbor2 said:Is there a way to remove the individual contacts from the medium to large sized Anderson connectors? I've never used them before and have been given a bunch of them.
https://youtu.be/3YegA_JYk9I
8 kW Enphase micros AC coupled to a SolArk 12K -
