Dismantling Anderson connectors.
littleharbor2
Is there a way to remove the individual contacts from the medium to large sized Anderson connectors? I've never used them before and have been given a bunch of them.
  • Estragon
    IIRC, the housing bolts together in 2 pieces and the metal connectors are hydraulic crimps.
  • littleharbor2
    I don't see any accessible bolts. Does the plastic housing pop apart somehow?
  • Ampster
    Ampster Registered Users Posts: 174 ✭✭✭
    edited December 2018 #4
    There is a lip on the contact that catches on a flat spring below it. To remove the contact you need to lift the contact at the front by prying a screwdriver or flat blade between the contact and the spring below. Then push back the contact with a flat blade or pull from the rear.  Here is a video for a SB50 but the big ones are essentially the same:
    https://youtu.be/3YegA_JYk9I
    8 kW Enphase micros AC coupled to a SolArk 12K
  • littleharbor2
    Very helpful. Thank you.
