additional pv panels
royz
Registered Users Posts: 1 ✭
I have one of NAWS rv kits 3 years old with 2 x325 kyrocera panels a Morningstar 60 CC and 4 crown 220 amp/hr batteries
my question is would the batteries and CC cope with an additional 200/250 watt panel my batteries are in good condition but I would like to have a little more storage capacity
IMO, adding another panel might be pushing it for the controller (assuming 12v bank, would be ok at 24v). You'd also want to check panel specs to see how it would fit in.
Adding batteries to a 3yr old bank probably isn't a great idea either. 5yrs is a good age for a GC type battery, and adding would likely age out the new along with the old. Probably better to work the existing ones harder for whatever life they have left, and plan for expansion when they croak.Off-grid.
I agree with @Estragon. I would not add batteries to a battery bank that old.
Personally off grid systems are rarely max out the charge controllers capacity if you are using the top 30% of the battery bank. I'd think adding up to 325 watt panel would be fine. At first glance it would look like 975 watt array would be way out of line for a 60 amp charge controller. But in general you will get a max of about 750 watts off the array when the sun is within 15-20 degrees of perpendicular angle to the array. Consider your charging voltage by the time this would happen would be near or at absorb for your bank or around 14.5 volts so 750 watts ÷ 14.5v = <52 amps. In reality, you will likely never max out the charge controller unless you angle your panels to catch the morning sun and run them very far down at night.
I would see if the extra energy to keep things running during the evening hours and morning from the array, helps you use less energy from the battery bank. You might also practice some load shifting, doing what you can when the batteries have reach float and you have the extra energy coming from the sun that could be put to use! Perhaps you can extend the life of the battery bank to 4-5 years before replacing it.
Your 325 watt panels are likely 72 cell panels. Adding some 60 cell 250 watt panels to your array isn't a good idea. If you can find some 190 watt 72 cell panels they would match up , voltage wise, better with your 325 watt panels.
- 230 Forum & Website
