Small Camper Van Solar Setup
                    Crystal
                    Solar Expert Posts: 128 ✭✭✭
                    Hi,
I am looking for help designing a simple 12volt all DC solar powered system for my camper van.
Hoping to keep the budget under $200.
I am living full time on the road and always boondocking.
I require very little power...I live simply.
Just want to run a propane heater blower fan, dc cooler, and maybe a couple led lights.
All these will not be running at same time all the time.
This is what I figure I'll need...
1 - 50 watt panel
1 - 12volt rv/marine battery
Charge contoller
Now will a PMW be sufficient or will a MPPT really be neccessary?
What brand solar panel and charge control do you recommend?
Thank you for the information in advance.
1 - 50 watt panel
Charge contoller
            What is the amp draw on the heater fan, and the dc cooler? What is the appoximate duty cycle for each (eg heater runs 24x7 vs an hour in the evening)? Fridge is typically 1/3 duty cycle (actually running 8hrs out of 24), but my portable DC cooler appears to run constantly by design.
 Based on the above, you can size battery. A marine "deep cycle" probably isn't the best option.
 A PWM will likely work best. MPPT generally benefits long pv wire runs and cold ambient temps.Off-grid.
            A propane heater... That can be a big power user... A typical RV heater with fan draws around 8 amps @ 12 volts. Cold night, run 1/2 time,- 10 hours * 8 amps * 0.50 duty cycle = 40 Amp*Hours
 And to recharge that:- 40 AH * 14.5 volts charging * 1/4.0 hours of non-winter sun = 145 Watt panel minimum (suggested).
 DC Cooler (refrigerator)? That can be all over the map--But any active cooling system is going to consume a fair amount of energy--The wrong one can draw a huge amount of energy.
 Anyway, two ways to design a system... The best is to understand/measure your loads and when/where the system will be used--And design the system to support those loads.
 The other way is to "pick something" (size of battery bank, size of solar panels that will fit, $$$ to spend) and design a system. Then make sure the designed system will support your needs (i.e., a small system, no forced air propane heater)....
 For example, a 50 Watt solar panel for a full time off grid system, I would suggest a 10% rate of charge:- 50 Watts * 0.77 panel+controller derating * 1/14.5 volts charging * 1/0.10 rate of charge = 27 AH @ 12 volt battery
 http://www.solarelectricityhandbook.com/solar-irradiance.htmlOmaha NebraskaMeasured in kWh/m2/day onto a horizontal surface:
 Here we are in Oct/Nov... Something like 2.5 hours of sun:Jan Feb Mar Apr May Jun 1.92
 2.55
 3.64
 4.60
 5.46
 6.26
 Jul Aug Sep Oct Nov Dec 6.18
 5.41
 4.47
 3.17
 2.07
 1.67
 - 50 Watt panel * 0.61 DC off grid system eff * 2.5 hours of sun (fall) = 76.25 WH per day rough average
- 76,25 WH per day / 12 volts = 6.4 Amp*Hours of harvest "average" fall day
 If you are driving every day--The vehicle charging system would supply most of your energy for charging the battery. If you are parked for days/weeks at a time, and want to use solar only... Then the sizing needs to be much more "exact". Otherwise, you will just keep killing your battery (battery will last weeks/months before needing replacement) and you will be without power much of the time.
            Thanks for the in depth info.
 I looked for specs on both the heater fan and the cooler to no avail.
 According to a search I found the Igloo Powermate 40 dc cooler takes 5 amps.
 I believe the heater is a catalyst. It ignites by itself.
 The heater fan I can figure no more than 8 amps right maybe less since it a catalyst?
 I will only run the heater for a few hours each night and a bit on chilly mornings.
 The cooler will be ran as needed. Will use ice if necessary.
 Lights used minimally since I have luci solar lights that work really well at them moment.
 Possibly 100 watt panel would be more accurate for my needs?
 Would this be sufficient with just one 12volt battery?
            The typical RV heater fan is ~8 amps for everyone I have looked up...
 For the Igloo cooler, that is a thermoelectric type cooler.
 https://en.wikipedia.org/wiki/Thermoelectric_cooling
 There are many good things about TEC, however, temperature drop and electrical efficiency are not good (in a warm climate/car, they do not cool that well--Roughly 35F below ambient; and they take ~4-5x or so more electricity vs a good refrigeration compressor). Not a good candidate for running off a small solar power system.
 Ice for the cooler is one option... Another is some form of compressor based portable cooler, or propane based. Especially if you are going to be dry camping for longer periods of time.
 Here is a link/review of various cooler options... Look for refrigerator compressor based... Do not bother with thermoelectric unless you are driving or setup in a hotel room:
 https://www.fabathome.net/best-electric-cooler/
 If you are going to go with a small solar power system... Then a propane based RV refrigerator is your better option (you should be able to go 1-2+ weeks or so on a 20 lb propane cylinder. Of course, it needs to be vented to the outside for fresh air and fumes.
 RV absorption type refrigerators that run on propane--Many have 12 volt and 120 volt power options. Just beware, propane refrigerators are terribly inefficient when running from electricity (i.e., don't run on 12 volt battery power from a solar power system).
 Sometimes you can find a good one in an RV wrecking yard.
- 232 Forum & Website
