Newbe setting up solar on boat, layout ideas. comtrollers
I have such a tight schedule I have not posted much, would like to share more.
Project 1: rig new boat (2003) for
Caribbean trip Dec 1.
New Batteries, 5 8Ds replacing the 48Ds, No more space.
4 – 270 watt solar panels = 1080 watts =~77ah
210 amp Idle pro Alternator/ Balmar regulator On hold mounting problems
A case of rum
I am a Newbe to solar, bought 4 370 watt panels for a boat. The panels wiil be mounted on a flat roof on the rear of boat. Set in a square, could be some shading on two at times. Silfab 370 watt 39.7 volt 9.39 amps. New boat batteries AGM or Gel 1250ah five 8Ds. 12 volt system.
QUESTON; suggestions on set up, I would prefer one MPPT, easier to set up. But I just bought 2 60amp MPPT. Really pushing a deadline.
Based on what I see here (and guessing), I would just run the 4 panels in parallel (Vmp-array~40 volts, Imp-array~40 amps).
Solar electric panels just do not work well when shaded (the cells go "high resistance" when dark, need bypass diodes to pass current around the ~12 volt block of shaded cells--if just one block).
Mount/orient the panels so that they have at least some chance during the day of running without shading (no lines crossing the panels either).
Other question--are panels for when moored? Or for use at sea, or both?
If use when moored, then if docked or prevailing winds/current (anchored)--Then mount panels favoring the direct of sun (south east through south west if north of the equator.
You can use a solar panel hours of sun estimator to figure out angles and direction to point:
http://solarelectricityhandbook.com/solar-irradiance.html
If this is when under sail--Unless you have standard course and time of day (going north during the day, sailing south at night)--having 2 panels to port and 2 panels to starboard--With separate MPPT controllers (one for port, other for starboard)... But I would try with just one controller anyway (save space and keep a spare--sea water is tough on everything).
Anyway some thoughts...
Solar panels are difficult animals to get any large amount of power from them on a moving sailboat... Assuming you will get a minimal amount of power (10-30%) and make your minimum energy usage less than that (GPS, Autopilot, Radio, LED lighting/running lights)--That would be about all I would count on. Use a genset/boat generator for larger amounts of power (refrigeration, cooking, computers, etc.).
We have had people try the solar only power for their trips (sailing competition from US to Hawaii, if I recall correctly), and they ran out of battery power before they completed the voyage.
If a bit of speed loss is not a huge issue--A towed propeller and alternator may be more effective if you are under sail much of the time...
http://svsarah.com/Whoosh/WhooshPacificPrepTowGenerator.html (don't know anything about website or product--Just an example for discussion)
One thing I forgot to add, if you put all for panels in parallel, you should use a circuit breaker based combiner box--If one panel gets shorted, the other three panels can feed current to the short and start a fire--Each panel/string having its own circuit breaker (probably around 15-20 amps, check solar panel specifications) reduces the chances for short circuit fires (for 2 panels or less in an array, a combiner box is not needed).
And some tools... If these are Flooded Cell Lead Acid batteries get a Hydrometer to monitor the state of charge of the bank:
https://www.solar-electric.com/search/?q=hydrometer
Rinse the hydrometer with distilled water prior to putting away (and glass hydrometers are always very easy to drop and break).
And get a DC current clamp DMM (digital multimeter)... Makes debugging DC (and AC) power circuits much easier and safer:
https://www.amazon.com/gp/product/B07546L9RT/ref=ox_sc_saved_title_7?smid=A1GODHR53OMQWV (cheap and good enough for our needs)
https://www.amazon.com/gp/product/B019CY4FB4/ref=ox_sc_saved_title_4?smid=ATVPDKIKX0DER (mid price/quality meter)
Bill,
This boat is a powerboat, it has a flybridge with a radar arch no telling what telling what direction the sun will hit the panels. Solar is for travel and for at anchor. When you anchor the boat swings around and faces the wind you are right hoping to topoff batteries have a 12kw Genset for real power needs.
I just bought five 8D AGM today, 1250 ah thanks for the tip on the DC clamp. I had bought one and found out later it was AC only could not find a DC clamp so thanks again.
If I setup the panels in parallel will I have a 160 volts and still 9.4amps? Do you think I should put a 15-20 amp fuse between each connection of the four panels? Open for anymore advice. Just read about MC4 fuses on this forum, is that what you were talking about?
Thanks for your response
Steve
The max string fuse size should be listed in the panel specs, typically ~15a.
In parallel, total array voltage will be roughly that of a single panel, total current will be roughly panel amps * number of panels (so 9.4*4 in this case.Off-grid.
As Estragon says... Solar panels are just like batteries... Connect them in parallel, current adds. Plug them in series, voltage adds.
Since the boat has no static orientation to direction, mounted flat would probably be the only logical position, the output may be less than than expected, unless you're at the equator.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 231 Forum & Website
