Sizing portable PV system for daytime Electric Skateboard recharging
caruzer
Registered Users Posts: 3 ✭
Greetings,
I have an Evolve Skateboard. It's listed as having 3000w of power (not sure if that refers to the motors or the battery). More specifically, the battery is: 36 V / 10 Ah / 360 Wh / 10S
My charger/transformer outputs 42V at 2.0A
I am looking for a portable panel system that will allow me to charge it up during the day. I don't need to store power to recharge at night.
What size system do i need? I get lost in the weeds when trying to calculate....
thank you!
Michael
thank you!
Michael
2a@42v=84watts, so about 100w panel. The problem is the voltage. Most panels that size will put out ~18v, so you'd need a charge controller that can boost voltage to 42v, or a small 12v battery charged by the panel and small 12vdc to 120vac inverter to run the 42v transformer.Off-grid.
Thanks! I have a few deep cycle Marine batteries. and can grab an inverter. Would a 100w panel provide enough to generate a full 120v current (like the house) to power the transformer? or would it drain the battery trying to keep up?
42V @ 2 A = about 100 w allowing for 20% inverter losses. At 12V, thats 8.4 amps.My suggestion: Try a single 12V deep cycle battery, a Morningstar SureSine 300w inverter and about 200w of panels and appropriate charge controller.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
thanks Mike!
- 230 Forum & Website
