Same sun different charge rates
Plucka
Registered Users Posts: 130 ✭✭
Yesterday lithium batteries were 13 volts @ 9 am and solar mppt charger was putting in 17.6 amps. Today same weather batteries were 13.3 volts @ 9 am but charger was only putting in 15.6 amps .Is this normal or has a bird done it's business on my panels?
Higher voltage lower current, day to day temperature difference, different state of charge to mention a few possibilities, not something to be over concerned with, IMHO.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
As mcgivor notes, within normal day-to-day variation. If worried about a bird bomb, by all means go look with a damp sponge. Could also be an errant leaf or twig. I'd also ignore it unless it was a persistent problem.Off-grid.
today is cooler -probally the difference. thanks
