Best battery SG tester you have come across?
alyaz
alyaz Solar Expert Posts: 114 ✭✭✭
Sorry if this has been discussed... did a quick search and didn’t see anything...
Anyone using / used one of these and do they make life any easier?  Would you recommend it, or something else?  Thanks.
https://www.solar-electric.com/midnite-solar-battery-hydrometer.html
3.3 kW solar.  3 Midnite Solar controllers; 5 lightening suppressors.  Magnum’s inverter; auto gen start, BMK.  Davidson 2 v FLA’s - 24v bank.  Perkins diesel gen.
    You are asking one question and wanting a different answer.
    A hydrometer is just that a meter. It measure specific gravity. I own that one and compared it to glass hydrometers I had been using before trusting it and it works fine for me.
    There is also a battery "tester". The most common of which puts a load on a battery and helps test the capacity. A battery with little capacity will have voltage drop and continue to drop. One with reasonable capacity will drop then hold steady at some point.
    Battery Load Tester;
    Image result for battery load tester
  • Estragon
    I also have both the one linked and a glass version. Both have to be rinsed thoughly between uses, and both sometimes need 2-3 draws to get a stable reading, but I personally find the linked one easier to read and less likely to need repeat draws.
  • alyaz
    Just purchased one, thanks gang.
