Charging battery’s I figured I could charg
The picture of the roof jacks I found online.
This picture I, too,pulled off the internet because I don't have any photos of any roof jobs on my own. If I were doing this job I would have done a closed cut style valley like the roof on the right, roofing through the valley with the material from the smaller roof section, (if one was smaller), then bring the shingles of the larger section to the valley in a clean cut.
So how's about the battery situation, or are we meandering into a roofing forum... joking of course
It appears that way.mcgivor said:So how's about the battery situation, or are we meandering into a roofing forum?
If you over panel like u are suggesting I think the biggest problem u will have most days is not "will my batteries get charged", but rather, "what can I do with all this excess energy potential" that is not being generated from the array because it is not needed for charging or loadsREC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array / MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware / OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system / Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2017 / System, Pics and Discussion
I’m not sure about the battery’s I left the house Monday AM and have not gotten back up there yet .
Heading up there tomorrow morning I have to assume things have been taking care of themselves ,
I will post a up date tomorrow
LH. Back in the day taking pictures of our work was a pain , now every one has a camera in there pocket .
I have guys snapping pics all day long .
Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
If you can get them off their damn phones long enough to take a pic.
Mr M1 I’m not really worried about most days .
Im worried mostly about December , nov and January are bright compared to December , then
there are the days of snow . And the weeks of below -0 .
I do seem to get sun for a few hours every day or so .
Good thinking, worry about the potential deficit before being concerned with potential credits, that can be done once a baseline is established.wellbuilt said:Mr M1 I’m not really worried about most days .
I do seem to get sun for a few hours every day or so .1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Based on my experiences so far, if you can make it now,, Bulk- Absorb and into Float, with,say 1000W STC (Name Plate value) you will need at least 50% more in the dead of winter, all of Dec and 2+ weeks into January just to get through ABSORB...because of the lesser # of hours and the weakest strength sunlight for the whole year and the worst weather...hth
I'm not knocking u for the idea. I over paneled my set up for its location too. But I did find myself looking for ways to utilize more of the power available from the array on sunny days. Ended up wiring a hot water heater diversion loadREC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array / MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware / OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system / Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2017 / System, Pics and Discussion
Ya I hate the cell phone , for a few years I would lock the phones up on the job and the boys could text on break and lunch .
Then I figured they would have to man up and control them selves .
I would look on the phone bill at the end of the month and just charge them for the time .
How about smoking I hate smoking back in the day you could smoke all you want as long as you where cutting wood and nailing .
Now there is a hole reason to walk to there cars smoking to check there phone and shoot off a text .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Every thing was ok with the battery’s 1 was at 100% charge for 3.7 days so it took about 2 days to bring the charge up 21% I think that’s ok for now .
Sun is only hitting my panels 6 hrs a day now .
Funny thing is my mate graft bar stoped working , the solar power is shown on a little graph with a KW reading
the power usage is also shown with a graph and a killawatt reading but the graph doesn’t work ?
I’m not sure if it ever worked ?
Any thoughts ?
I’m trying to charge with my genarator now and I’m getting a fault
it reads generator frequency to low
I’m around 115 to 120 volts 54.7 to 55:2 hz ant thoughtsOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Some gensets need a simple load (a couple of 100 watt filament lamps or an electric heater) to stabilize voltage and frequency. Then apply the frequency/voltage sensitive loads (like an inverter-charger).
Otherwise, getting your nominal frequency closer to 60 Hz by adjusting the genset would be a good idea.
Some inverter-chargers have a frequency range setting... Perhaps you can adjust lower? (that will, I am guessing, also let the 55 Hz AC output from the genset go to your AC loads too--May or may not be an issue).
Thank B.B. I was thinking 55 was the magic number ? Brain over load .
I hate rainy days 🙁Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
You might also want to check and maybe increase the inverter connect delay setting to let the genny warm up a bit. IIRC mine default to 30secs and I upped to 1 minute.Off-grid.
It all depends... A mechanically govern genset is probably 60Hz +/- 5 Hz for frequency stability. Getting down towards 50 Hz, 60 Hz rated transformers and induction motors will start having problems (overheating, etc. if operated near rated power/VA).
I had to increase the run speed a bit based on the Kill A Watt meter, the voltage went up a tad but the saws etc like it better with the correct Frequency
There are many intricities involved with building an off grid system, relying on information provided by technology is not the sane as knowledge, as stated in post#3 don't attempt use a system before it is complete, generally I'm not in the habit of peeling my potatoes twice, but if you must, check the settings for frequency qualification and adjust accordingly.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Ok I Tickle the generator a little and I’m charging , that’s the good news .
The bad news is it seams like the mate is Systematically shutting down starting with the graph ?
Things with the mate seam to be going out of wack ?
I’m still working with it .
But a lot of the buttons don’t seam to work and the screens seem to contradict themselves ? ThoughtsOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Shut down all power to your system. Let sit for 5 minutes. Then turn on DC battery power first, then power up rest of system (solar array power, genset power, etc.)... My first guess.
If there is a "system restart" command (reset to system defaults)--I would try that too... There are times when a "wrong value" is written to the setup storage and the software uses it--And goes "nuts" with the invalid data....
Oooooooo I hate computersOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
The graph should show power going out at the screw point just like the solar graph is showing power coming in ?
Things started looking funny when this graph died .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Yes I have read post #3 and under stand what you Guy are telling me .
Im not really using the system I’m just testing as I go , looking at the parts an pieces I have limited time to work here now , and I’ve been figuring thing out Buying parts at home and on line .
It looks like I will have time in a few weeks and will get the panels up .
I just want to float the battery’s and use the genarator pass thru for lites and radio
I’m still running power tools off the genarator .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Hi all new question ,
I have 2 banks of 8 gc215 battery’s .
I need a 175 ap fuse for the battery terminals
do I put a 175 amp fuse on each battery or say a 85 amp fuse one on each battery or combine the battery bank then add I 175 amp fuse ?
Thank in advance for the help . JohnOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
I'd put a 175 on the combined bank.Off-grid.
Personally I would ask the question what size the conductors are before recomending an over current device, after all that is the purpose of such a device, fuse or circuit breaker, to protect the conductors not the devices fed, although it can protect devices, that is not the primary purpose.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
@mcgivor - good point. I assumed John had already worked out the correct OCD size for wiring and devices ("I need a 175a fuse..."), but that assumption may be incorrect.Off-grid.
I have a 3600 watt inverter with 02g wire size of my thumb ?
I’m not sure where the 175 amp fuse came from .
Maybe the breaker on the inverter is 175 amp or I read it some where .
Could I run both battery banks with 02g wire to this fuse @ 175 amps then run to the inverter
