Step down converter to run 1000 watt 12v inverter on 24v bank
chriselks
chriselks Registered Users Posts: 13 ✭✭
Is it possible to run a 1000 watt 12v inverter on a 24v bank if I use a step down converter rated for 20 amps?
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,122 ✭✭✭✭✭
    Seeing as how a 1000 watt 12 volt inverter would draw up to 160 amps while surging to peak output, no.
  • Estragon
    edited July 2018 #3
    I suppose you could if you put a 20a (dc rated) breaker between the converter and inverter, and a 10a between converter and bank. Hopefully at least one breaker would open before the converter blew up or wire melted.
    There's also a risk that the converter fails in a way that exposes the inverter to 24v bank voltage (say low 30s in EQ), which may not make for a happy inverter.
    All things considered, there may be better solutions.
  • chriselks
    If I don’t have dc rated breakers available might I be able to use fusible links? I’m only going to be doing this temporarily until my new inverter arrives in one week. My old 24v inverter failed on me
  • Raj174
    Can you rewire the batteries temporarily for 12 volts?
  • Estragon
    It would help to know what you're trying to do. Running a 12v inverter in a pinch off a 24v bank might be feasible for a bit. Not something you'd want to do for long, but might get you through a week or so. Do you have 12v charging available? What size is the 24v bank? What loads do you need to run off the 12v inverter?
