Off Grid Motor Help
evenwiz
Registered Users Posts: 3 ✭
Hello everyone. First off I am not familiar with off grid solar other than knowing I need certain critical components. Will appreciate if someone can guide me.
I am trying to get a 15Vdc, 1A motor working by attaching to a solar panel with a charge controller and battery. The motor will not be operating 24/7. It will only be turned on 2-3 times per hour a day and it's operation duration around 2-5minutes only. The problem I am having is knowing what should be the specifications for the three components to power this fellow.
Will appreciate if someone can help me out here! Thank you!
Will the motor be needed only during the day?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Yes, only use during the day. Forget to mention that the motor is to power the window blinds. The motor has an on/off switch on its own.
Reason I asked was it could be powered directly by a panel without needing a controller or battery, but it would be better with a battery, given the use
The calculation below is assuming maximum useage.
3 times for 5 minutes per hour for 12 hours would be 180 minutes total or 3 hours
3 hours × 1 amp = 3 ampere-hours (Ah)
Battery capacity needs to be greater than maximum useage by at least 50% so 6Ah minimum 10A better
PV module or panel wise a 30 to 40 watt one would be in the ballpark to maintain the battery
A cheap 5/10 amp PWM controller would be fine for this very small system
This would be a system where the solar does most of the work during a sunny day, providing battery backup should there be limited or no sun.
Thank you mcgivor! I will headstart from here and try it out.mcgivor said:Reason I asked was it could be powered directly by a panel without needing a controller or battery, but it would be better with a battery, given the use
