mixing strings of panels??
Wbuffetjr1
Registered Users Posts: 92 ✭✭
I HAD 3 strings of Solar Word 345 watt panels. One string is demolished. I can longer buy the 345 watt panels , but can buy the Solar World 350s. If I have 2 strings of 345s and 1 string of 350s will that be a problem? Classic 200 charge controller.
Thanks for the input
Shouldn't be a problem at all. Looks like it is actually the identical panel, but has tested out to a slightly higher efficiency. Vmp on a string of two would be 0.6V higher, which is less than 1%. Go for it.Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 8S (25.6V), 230Ah Eve LiFePO4 battery in a custom insulated and heated case.
Even identical panels can vary a bit (eg part of an array gets a cooling breeze). If the frame still physically fits, it should be fine.Off-grid.
great! Thanks fellas!
Tough luck with that tree fault detector circuit. Hope the fix is not too much of a pain.
- 228 Forum & Website
- 618 Discussion Forums/Café
