Ground Fault error on Classic 200
![Wbuffetjr1](https://w7.vanillicon.com/73ebfcf37538ec11511ffef92827dc2c_100.png)
Wbuffetjr1
Registered Users Posts: 92 ✭✭
Monitoring my Classic on My Midnite and it is showing a ground fault error message. System is showing normal "PV volts" but no "power". After running flawlessly since last July this has just popped up. My system is 1,800 miles away. The error occurred one afternoon that there was some really ferocious winds, but no rain or lightning.
I have a buddy going up to check on it tomorrow. Any tips on the first things to look for that would cause this?
48V bank with 3 strings of GC batteries.
Here is one cause of a Ground Fault error
That's nasty!Off-grid.
Ah man! That really stinks!Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 8S (25.6V), 230Ah Eve LiFePO4 battery in a custom insulated and heated case.
But it's insured... right?
Rancher -
Ha! No insurance.
Personally, I probably wouldn't claim it anyway. Between the deductible and a claims free "discount" (ie they jack up your rates after a claim), it's likely better not to claim unless part of a larger loss IMHO. Hopefully, the rack can be straightened and doesn't need to be replaced.Off-grid.
How many panels were lost? Could have been worse, if that's any consolation, looks like 2 for sure.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
yes two panels lost, but thinking I will have to buy three panels to replace (started another thread about it - those EXACT panels aren't available anymore). I wouldn't claim it either. MT Solar told me they will sell me the individual parts to replace the bent pieces. Very impressed with MT Solar all around.
Could have been a lot worse! I have been very lucky over the years with dodging things like this. I can't complain when it does happen. -
You and a lot of us face that potential issue daily, every time the wind blows... Looks like Alaska ?? Canadian Shield? or just outside my door.... waiting for those warm southern breezes to come up the valley and finish the melt, lake not open yet either...
If the third panel of that string is still functional, you really only need to replace the two that were wrecked. Mixing the panels you were considering in the other thread is no problem.Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 8S (25.6V), 230Ah Eve LiFePO4 battery in a custom insulated and heated case.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
