Whirlpool, 110V, 6.5 amp refridgerator
zilchll
Registered Users Posts: 2 ✭
What would I need to run this fridge alone, no other items attached?
The numbers you provide are likely the peak numbers. 110 vac. x 6.5 amps = 715 watts. My 14 cu ft. fridge after monitoring with a kill a watt meter draws .75 amps while running. I never have tried to find the peak wattage being that our inverter is much larger than needed to kick start the fridge.
Looks like a 1000 watt PSW inverter will handle the start up load.
Without any information on what is actually powering the refrigerator, be it an inverter powered by a battery or whatever , it would be irreponsible to answer such an open ended question, without knowing the details, location ambient temperatures etcetra, these are factors which will determine sizing of array. . Only my opinion, FWIW
For a standard, modern, energy star refrigerator, generally a 1.2 to 1.5 kWatt (1,200 to 1,500 Watt) AC inverter is recommended... It will generally also run a few lights, radio, cell phone charger, etc...
What you do need is to measure the amount of energy per day (Watt*Hours) using a Kill-a-Watt or similar meter:
https://www.solar-electric.com/kiacpomome.html
Nominally, for an off grid energy efficient home, I would suggest around 3.3 kWH per day (3,300 Watt*Hour) system. If you really only want to run a refrigerator, lets assume that it draws around 548 kWH per year or (547kWH/365 days per year=) ~ 1.5 kWH per day. A full time off-grid "reliable" system may look like (loss of guesses here about your specifics). First sizing the battery bank:- 1,500 WH per day * 1/0.85 AC inverter eff * 1/24 volt battery bank * 2 days storage * 1/0.50 max battery discharge (for long life) = 294 AH @ 24 volt battery bank
Note: A 400 AH @ 24 volt battery bank will support a suggested maximum ~2,000 Watt AC inverter and ~2,000 Watt solar array. Larger AC inverters typically waste power and will empty the battery bank very quickly if heavy loads are used.
We suggest 5% to 13% rate of charge, with 5% good for weekend/emergency usage in sunny weather, to 10%+ for full time off grid:- 400 AH * 29.0 volts charging * 1/0.77 panel+controller deratings * 0.10 rate of charge = 1,506 Watt array "nominal"
http://www.solarelectricityhandbook.com/solar-irradiance.htmlTucson
Measured in kWh/m2/day onto a solar panel set at a 58° angle from vertical:
Based on hours of sun, seasons, and 1,500 WH per day, and a derating of 0.75 (you do not want to use 100% of your predicted power per day--Unless you have a backup AC genset for some days of less than clear weather):Jan Feb Mar Apr May Jun 4.95
5.63
6.61
7.07
6.91
6.56
Jul Aug Sep Oct Nov Dec 5.77
5.66
6.09
5.84
5.30
4.76
- 1,500 WH per day * 1/0.52 off grid system AC eff * 1/0.75 "no genset" fudge factor * 1/4.76 December average hours of sun = 808 Watt array minimum for "nominal" December usage
The above is a quick back of the envelope calculation for a "reliable" off grid system to run a standard Energy Star Refrigerator. Hot weather, using the ice maker, etc. can cause a fridge to use significantly more energy.
You can, of course, go with a smaller system (like just one string of golf cart batteries and an ~808 Watt array)--But that does mean you will have to monitor the system more closely during hot or cloudy weather. Also note that I am using "accurate" numbers like "808" so you can follow me where the numbers come from... For solar power, +/- 10% (i.e., and array that is 800 Watts +/- 80 Watts in size) are pretty much "the same". Solar power numbers are "estimates"--Not etched in stone.
mcgivor said:Without any information on what is actually powering the refrigerator, be it an inverter powered by a battery or whatever , it would be irreponsible to answer such an open ended question, without knowing the details, location ambient temperatures etcetra, these are factors which will determine sizing of array. . Only my opinion, FWIW
Right now, the fridge is unplugged and not used. It is about 7 or 8 years old. I said it is 110 but I do not know the difference between 110, 115 or that stuff. It is a Whirlpool 10.7 cu. ft. When I looked it up online it said it was 6.5 amps. It is in a tight spot so the plate is hard to get to. We want to use solar to run it full time, if possible. I guess we need a panel and inverter, at least a 1000 watt? -
Do you currently have grid power and are attempting to power the refrigerator with solar in an attempt to save on the costs versus of running on grid, or are you in a location without grid and are in need of refrigeration? These are very important questions that need to be answered, because solar energy is not cheap, in fact it will cost way more than grid, anywhere any time, based on global grid energy prices.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I'm running a somewhat smaller fridge (rated 311Kwh/year) off the system listed in my signature. So far it seems to be working fine.Island cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year.
- 621 Discussion Forums/Café
