Conext Bridge for XW+ Li-ions from LG and Hoppecke announced for 2nd half 2017
I see the shovel on the upper right. Were you tired after you dug this?
Looks pretty firesafe in the lower 3/4 of the picture
Hey Eric
don't tell me the back-hoe showed up after you hand dug most of it? I see the shovel up on the right?
looks pretty safe in the lower 3/4 of the picture..."we go where power lines don't" Sierra Nevada mountain area
Dave, that was a reference stake with the orange tape.The shovels came out with the adjustments needed for the basement door before the concrete laying...
Being a newbee on the backhoe I took about ~ a month to get 'to the bottom of things', also had to move the dirt ~ 100 yds away for temp storage. No Swamper available, at least on that could look thru the level eye piece...
That material circles the whole place for ~10 feet, mostly fine sand...
Oh good! My master gardener said to me "we are worldwide organization" She also told me you will have to bring in more dirt :'(
As they say to "amend the soil"....Good luck on the project."we go where power lines don't" Sierra Nevada mountain area
We are lucky as that sand has just the right amount ( very little) of clay to hold soil moisture, yet allowing H2O penetration and not compact when walked on.
Has anyone in the states been using the xw with the lg yet,apart from Dave? I keep ringing lg here { australia} but for some reason they will not warranty the battery in an off grid application here yet.
Drop me an e-mail please. The LG RESU10H is being used here instead and is for sale at my suppliers stateside."we go where power lines don't" Sierra Nevada mountain area
Bennyspoon, which Schneider inverter you are using is it XW6048?
Thanks Dave, sent through.
gbaig the inverter is an xw+ 8548, not using it yet though,waiting for the battery.
Hi,
Sorry if I am resurrecting an old thread but my searches so far have only led me to this forum. I've read this entire thread.
I have a SE XW+ 8548 and am trying to get more info on the Conext bridge, specifically what makes of Lion batteries it is compatible with but still cant find the compatibility matrix mentioned in the 2 page bridge pdf. or what Lion's I can use without the bridge for that matter.
My lead acids are end of life and I'm looking to replace with Lion, just want to make sure they are all verified so the install is safe.
Thanks in advance
This is a discontinued project by LG Chem. Schneider electric has moved on to a much better solution with the Gateway. There are several solutions I use for my clients. Schneider provides RS485 and canbus inputs into the gateway to allow battery manufacturers to use their BMS to close loop charge and get battery state of charge out to Schneider power system monitors. These are called Insight local and cloud. Here is a link. You are welcome to contact me below. It has been an interesting ride back in time when this was very new for everyone.
https://solar.schneider-electric.com/product/conext-gateway/
