3 Blades vs 5 Blades
Re: 3 Blades vs 5 Blades
not even long enough to get your first electric bill -
I'm a middle school student and i'm working on a project about wind turbines my hypothesis was if 3, 6 and 8 blades put on a wind turbine 3 blades will produce the most electricity. but my results show that 6 blades was the best and 3 blades was the worst. I didn't find any reason why?
now I should write my conclusion that why 6 blades was better the 3 blades and I should give a reason why? I don't know what to do. do you have any suggestion for me to write in my conclusion? -
There difference between a 3 blade and 6 blade is, the 3 blade can operate at higher speeds before the blades begin entering the wake of the other blades, which is favorable for electrical generation. However a turbine is used for direct power, such as pumping water, where speed is not as important as torque, more blades such as 6, will be benificial because speed is not a requirement, therefore blade turbulence is less of an issue. See link for more information
https://www.quora.com/Why-is-3-the-optimal-number-of-blades-on-a-wind-turbine-instead-of-say-5-or-more
bmet said:Re: 3 Blades vs 5 Blades
not even long enough to get your first electric billlucymarco said:I'm a middle school student and i'm working on a project about wind turbines my hypothesis was if 3, 6 and 8 blades put on a wind turbine 3 blades will produce the most electricity. but my results show that 6 blades was the best and 3 blades was the worst. I didn't find any reason why?
It may be that the generator you are using reaches its threshold to begin producing enough "Charging Power" at a lower RPM and doesn't need the speed. So, the three blade rotor may not grab the low speed air as well as your 6-blade rotor, therefore more low speed wind slips by the 3-blade rotor than spins it.
Use this link and go asked the maker/seller of various small size wind generators why he sells wind generators that have 3 to 9 blades making up his brands/models of blade rotors. If you find out, please post back here and tell what/why he sells so many variations of in the number of blades for his Win-Gens.
https://www.ebay.com/itm/DC-output-Confederate-3-blade-500-watt-12-volt-wind-turbine-turbulent-wind/292049663027?hash=item43ff843433:g:cG4AAOSw2gxYwGRO
Learn by Doing is a great way to understand and remember how and why things work.... ;>)
Bill
Bill -
john p said:Re: 3 Blades vs 5 Blades
im running an Air x now with 5 blades. 5ft dia as against the 3 blade 4feet dia
it definately is less noisy than when it had 3 blades. the manufacturer of the 5 blade set says its because the "holes " between the blades are smaller.. I have no idea except it makes a lot less noise
The generator starts making power in much lower winds than when using 3 blades
its production of power is much greater in high winds,
it was producing so much power in high winds it bent the 2" dia last 3 ft of pipe. had to add guy wires.
Very interesting thread. I would like to point out that higher RPM does NOT equal higher Power. Higher RPM equals higher Voltage. If you had a resistive load, higher RPM would result in higher power to the load. If you have a three phase rectifier and a PWM converter to give you a fixed voltage or a controlled voltage to charge a battery, the load on the turbine (power provided) would be relative to the current you are drawing. The more power you draw, the more load is seen by the turbine and the RPMs will reduce with the same wind speed. Run your turbine with no load, it will turn very fast but there is no power, add a dump load and the RPMs and voltage will go down, and there will be significant power dissipated in the dump load.
If you want to see the math that backs this up Calculations | Simple Electric Motors (simplemotor.com)
- 230 Forum & Website
- 654 Solar Water Pumping
