Vinyl Tube lost in Flooded Lead Acid Battery Cell...
openplanet
Registered Users Posts: 34 ✭✭
I use the excellent hydrometer sold by Midnite Solar and other vendors. Unfortunately, its little vinyl tube is only affixed with a pressure fit, and tends to fall off. I've now lost two such tubes (about .25" o.d. x about 4" long) in two different cells of my battery bank, and they're proving impossible to see, let alone retrieve. I've always been fastidious about keeping my battery compartment clean and minimizing contaminants in the cells. So the question is...will these hunks of vinyl damage the cells they've drowned in? Thank you.
I don't think they will cause any significant problem.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
I wouldn't go poking around inside of a cell with a screwdriver or pair of pliers to try and get it out!!!
I would think an internet search may tell if vinyl tubing dissolves in battery acid. Such tubing is usually either made of PVC (stiffer) or silicone (supple and more expensive) as I recall.
Midnite should know the answer...First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
You can look up chemical compatibility charts for various materials (page 46 for the following PDF link):
http://www.graco.com/content/dam/graco/ipd/literature/misc/chemical-compatibility-guide/Graco_ChemCompGuideEN-B.pdf
Use (I think) the ~50-65% concentration for electrolyte (sulfuric acid+water).
While a nice dig, I do not see PVC (poly vinyl chloride) mentioned. Nor do we know, for sure, what the tube is made of. Assuming that it is vinyl or PVC is a "good guess".BB. said:You can look up chemical compatibility charts for various materials (page 46 for the following PDF link):
I think black hose is often nitrile but can be rubber. Then we have blends as well.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
- 232 Forum & Website
