Xantrex Prosine 1800 24v - Fried
Ocean
Registered Users Posts: 46 ✭✭
Well, half fried. If I turn it on the output is about 65 volts. It happened one day when I tried to start a Compressor Motor with low batteries. Bad idea. Overload and then... meltdown. I've opened it up and looked around inside - nothing burnt... but I am not very knowledgeable about the electronics of these things - I'd love to fix it if I knew what to remove / replace.... any ideas for troubleshooting / figuring this out?
thanks...
-Ocean
thanks...
-Ocean
Check the fuses inside, also check the MOSFET.
How do you check the Mosfet???
There would be a bank of 2-8 MOSFETS and drivers and you need a multimeter with a transistor check function, and that may not even check mosfets properly.
thanks Mike I'll check to see if my multimeter has that...
