solar system for submersible pump
ceshydro
ceshydro Registered Users Posts: 4
We are trying pump water from a spring house over a 120 f00t hill to a village in Haiti.  We were given a Grunfos submersible 1.3 hp pump that I believe runs on ac or dc power.  We would like input regarding the sizing a solar system, and input on whether we need batteries,etc.
    Is there a part number/model number on the pump? Need to know exactly what you have to make sure that we have the correct tables/equipment for your needs.
    Also, will the pump be pressuring a water tank, or just filling a cistern? How far down is the village below the 120 foot hill (i.e., can the village water be pressurized by a cistern on the top of the hill)?
    Just pump during daylight hours? Or pump 24x7 (battery system needed for pressurization)?
  • ceshydro
    we will be pumping to cisterns during daylight with Grundfos model D P2 1316 submersible pump.
    Craig
  • jonr
    edited August 2017 #4
    I didn't find anything searching for that model number.  By far the easiest and most reliable design for solar is to use a Grundfos SQFlex pump.
    If you will be using AC power only--The SQ series is cheaper (I think).
  • Horsefly
    For sure. I was looking at the SQFlex initially for our eventual replacement pump, but I realized I would be paying much more for the DC/AC power flexibility that I really didn't need.
    As for the part number: I also can't find anything like that in Grundfos literature. The 316 probably is regarding the stainless steel housing, but the rest doesn't fit, at least relative to submersible well pumps.
  • ceshydro
    Here is the spec sheet info, Only AC?
    Product No.: 98163731
    The SQFlex motor range comprises only one motor size, the MSF 3 with max. power input (P1) of 900
    W. MSF 3 is a 3" motor. The speed range for the motor is 500-3000 min-1 depending on the power
    input and the load. The motor has been developed especially for the SQFlex system.
    The motor is designed according to the permanent-magnet principle with built-in electronic unit.
    Liquid:
    Maximum liquid temperature: 104 °F
    Technical:
    Approvals on motor nameplate: CE,RCM,EAC
    Materials:
    Motor: Stainless steel
    DIN W.-Nr. 1.4301
    AISI 304
    Installation:
    Maximum ambient pressure: 218 psi
    Electrical data:
    Motor type: MSF3
    Power input - P1: 1.4 kW
    Rated power - P2: 1.341 HP
    Rated voltage ac: 1 x 90-240 V
    Rated voltage dc: 30-300 V
    Rated current: 8.4 A
    Power factor: 1,0
    Rated speed: 500-3600 rpm
    Start. method: direct-on-line
    Enclosure class (IEC 34-5): IP68
    Insulation class (IEC 85): F
    Thanks,
    Craig
  • Horsefly
    That's the sqflex, so you paid a little extra so it would take either DC (30-300V) or AC (90-240V).  I can read pump curves, but others here are more pump-literate than me. I'll let them comment on how it should work in your situation.
  • jonr
    edited August 2017 #9
    My understanding is 200-600W of  panels wired for 30-300VDC (from above).  No batteries.
    Not clear is why some sources say that it will utilize a max of ~600W when above specs say the motor can draw more than twice that.  Perhaps an inverter limitation.
    Not at computer for the moment. But, as I recall, the SQFlex needs something like 64 to 96 VDC minimum to run the pump motor at rated power.
    Check the manual/specifications to be sure.
  • ceshydro
    Sorry Bill,  I have been away.  You are saying that we may need as much as 600 watts of panels.  I am mostly ignorant about this, but will consult the local solar company here.  The  folks on Isle a Vache thank you for your help.
    Craig
    Craig,
    You need to define the "lift" the pump will have to over come... Assuming 120 Ft lift, and 10% piping losses, and no top of hill pressure tank (pumping directly into top of open tank), you would use a chart like this:
    https://product-selection.grundfos.com/product-detail.html?productnumber=95027335&productrange=gma&lang=USA
    Note, it appears that you gave us the Motor P/N only. There are different pumps bolted on to the motor that offer much different pefromance numbers (i.e., high volume, low pressure vs low volume & high pressure).
    For the chart I linked too... 120ft + 10% (pure guess) piping losses = 131 feet ~ 40 meters of lift
    From the table, 40 meters and 600 watts gives you a rated (noon time) maximum flow rate of ~2.8 cu meters per hour (if I read the table correctly). And more than ~600 watts of panels will not give you more pumping volume (or pressure)--But will give you more hours per day of pumping (morning and afternoon pumping).
    Need more information--This is just an example that may very well be wrong.
