Batteries discharging at night with no load on
christo1985
christo1985 Registered Users Posts: 8 ✭✭
I have mounted 3x160w Poly's on the roof of my bus, connected in parallel to a 60a mppt charge controller ' sun shield pro solar' feeding 3x100ah lead acid batteries, The distance between the panels and the charge controller is less than 15 feet using 10AWG from panels to controller and 4AWG from controller to batteries, batteries are also connected in parallel with a ground to the bus chassis, i also have a 2000w inverter connected to the batteries, but it is always switched off when not being used.
i have 6 led lights and a small water pump connected to this system, Maybe using 2 of the 6 lights for about 1-2 hours every night and the bars on the controller seen to go from 5 bars to 3 bars within this short amount of time? and at night it will go down as much as 1 bar with no load on....  the battery v never gets less than 12.8v but the bar's on the controller get down?
Im not sure if i should change some settings on the controller or i have made a mistake with my wiring size or the battery bar indicator on the controller isn't accurate?
Any feedback would be great.... cheers
  • mcgivor
    The wire size from panels to controller are a little on the small size and would give you about 5% volt drop using 160W×3×.75 (average output) ÷14.4V=25A and the linked volt drop calculator, you want to be 3% or less. Are the batteries flooded or sealed,AGM, deep cycle etcetera, that would give some indication of what the settings should be. The bars on the graphic are at best an indication of charge, usually whilst charging, ~14.4V being fully charged, if the voltage is at 12.8V with no load overnight, that would be normal.
    http://www.calculator.net/voltage-drop-calculator.html
  • Thom
    Thom Solar Expert Posts: 196 ✭✭✭
    If using V I'd forget the "bars" and get a proper V meter. 12.6 in the morning is good
    Thom
    Off grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat
  • mcgivor
    Question, is this the controller you have, see link, the parallel arrangement would indicate a PWM not MPPT, also can you post the panel specifications on the back of the panels, always helpful
    https://www.amazon.com/Ramsond-Sunshield-Charge-Controller-Regulator/dp/B009AI4LVM
  • christo1985
    I really appreciate all the feedback guys..
    I have attended a few pic's hopefully this will answer you questions.
  • christo1985
    Not sure if the pics successfully uploaded?
  • Aguarancher
    Aguarancher Solar Expert Posts: 315 ✭✭✭
    you need to first click on the tab that says 'attach image' to load a pic.
  • christo1985
  • Aguarancher
    just an observation but the red wires should be on the positive side unless this is a positive ground system.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,180 ✭✭✭✭✭
    edited July 2017 #10
    One thing I notice is a li symbol in the bottom left corner of your CC screen. Is it set for Lithium ion batteries? As the voltage settles overnight it might think your battery is losing charge and giving you the less than full reading.
  • mcgivor
    edited July 2017 #11
    Good spot there @littleharbor2  pictures are worth a 1000 words.
  • christo1985
    That's funny.... the manufacturer told me the the LI battery stands for lead acid?
    Good spot, thank you for that. Should it be on GEL or something else?
  • christo1985
    Long story short, the red is now negative and black positive for the PV inlet, the angle of the photo also makes the load wires look like there in the wrong spot.
  • littleharbor2
    Don't know the ins and outs of your controller but  You should find in the manual an explanation.  FLA would be for conventional, Flooded Lead Acid. batteries AGM for sealed Absorb Glass Mat batteries. VRLA for sealed, Valve regulated Lead acid (AGM, Gel).batteries and Gel for .....you guessed it Gel batteries.
    Christo, you now have the colours backwards....  in  wiring DC systems  the black is the negative and RED is the POSITIVE..... in AC wired  systems the BLACK is the POWER (+) and White is the common
  • christo1985
    Hey west branch....
    When I did the wiring for the panels I made a mistake so I taped the ends, black is now positive and red negative, I know it's the other way around, amateur mistake
  • christo1985
    Thank you guys for the feedback! You have been awesome....
    I will change my battery type on my CC and see if that makes a difference ;)
