Battery choice?
usao
Registered Users Posts: 11 ✭✭
What type of battery is a good choice for off-grid system?
I hear some noise about using Lithium 18650 cells.
This appears to be a home-made option for creating multiple series/parallel loops using small replaceable 18650 cells which can be had for very cheap.
How does this stack up cost-wise and replacement wise against deep cycle lead/acid from Trojan or Surrette?
If you want to rig up a large homemade array of lithium cells, please keep a respectible distance from neighbours.
Lithium based batteries are getting closer to lead acid in some applications, but they aren't suitable for an on-the-cheap diy solution yet IMHO.Off-grid.
When questions like these are asked:
"Is this a good choice?" Or "How does is stack up.....?
The answers are always in the details. Things like system size, intended use and your experience are the beginning
It's a smallish system, dedicated to run bitcoin miners. Im looking at less than 10A @ 12V.
I had a grid tie system about 10 years ago, but it was a real bear to maintain the batteries. I was hoping the lithium batteries would be cheaper/easier as there is no monitoring/maintenance of the acid levels, just swapping out single cells as needed.
Ive seen youtube videos showing how to build them and they make holders to allow easy swapping.
