which panels are better
down under plumber
Registered Users Posts: 7 ✭✭
if I was going to have 2 strings of 3 panels in series in a rv 24v
would the PM 200w
Voc 22.8v
Isc11.1 A
Vmp 18.7
Imp 10.7
or The
Pm 200 w
Voc 46v
Isc 5.96
Vmp 38 v
Imp 5.26
thanks I have a Victron 150 V 85 amp charge controller
thanks Phillip
Personally I'd go with the second ones, more common, 3 strings of 2, the voltage would be closer to double the battery, unless there is a long run from panels to controller, then 2 strings of 3.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
What is the Maximum allowed Input Voltage of the Charge Controller?
145 volts starting & 150 volts absolute max ?
3 @ 46 Volt Panels in series = 138 Volts
On a cold day, 3 @ 46v Panels in series might be too high - not recommended
I prefer the second set of panels wired as 3 strings, where each string is 2 panels in series.
There would only be 5 amps flowing through the wires until combined near the charge controller.
- 234 Forum & Website
