PzS vs OPzS for off grid systems
liamg
Registered Users Posts: 43 ✭✭
Hello,
I've seen that almost everyone recommends the OPzS as the best choice for an off grid application (taking into account the 20 yrs life claimed by most of the manufacturers).
Anyway, looking at the detailed specifications, the OPzS has a 20 years life span in float operation and its electrolyte has a lower density (1.24 vs 1.29) in regard to PzS version.
Moreover, the OPzS are recommended for backup applications (UPS/telecomm), where the battery is actually spending the most part of its life in float operation. That means the electrolyte concentration will stay high for a very long time hence there is an increased chance of plate corrosion (that's why they choose that lower (1.24) electrolyte density).
Well, the float operation it's not exactly an off-grid/solar scenario, where you have to cycle the battery on daily basis. For that matter, this scenario is closer to a forklift/golfcart operation (though the discharge current is usually lower).
So, why should I choose OPzS instead of Pzs? The transparent case it's not the answer..
Batteries design for long term float may not be the best choice for daily deep cycles.
What does Trojan (biased?) report ...
http://www.trojanbattery.com/pdf/Trojan-Battery_Industrial-Line-vs-2V-OPzS.pdf
We need an unbiased "Consumer Reports" type test for Deep Cycle Batteries. -
mvas said:Batteries design for long term float may not be the best choice for daily deep cycles.That was my point, too. Then why everybody (well, except Trojan!) recommends OPzS for PV applicatons?mvas said:We need an unbiased "Consumer Reports" type test for Deep Cycle Batteries.That's true, I don't believe the linked Trojan report neither. Who are those "OPzS1", "OPzS2", "OPzS3"? What SG do they have?Apparently, there's no constructive difference (both using tubular positive plates) between the OPzS (float operation) and PzS (heavy duty deep-cycle) batteries, except for lower SG and (maybe) the Pb alloy used (to avoid plate corrosion during prolonged float operation).Then why is Trojan putting the blame on tubular (vs flat) positive plate construction??
PzS means Pz = PanZerplatte (tubular plate) S = Flüssig (flooded) "MOTIVE"
OPzS means O = Ortsfest (stationary) Pz = PanZerplatte (tubular plate) S = Flüssig (flooded)
I've read "OPzS vs PzS" ...
More electrolyte in OPzS (stationary) and Enersys uses 1.28 SG in OPzS (stationary)
Same efficiency
Same chemistry
Same electrical characteristics
But larger quantities of PzS type are produced for motive applications, this brings down the unit price of PzS vs OPzS. -
Still the OPzS are mainly recommended for telecomm use (mostly float) and their SG are usually around 1.24 (to avoid plate corrosion during extended float operation).Anyway, my question was: isn't the off grid operation more similar to a traction scenario (daily (deep) cycling)? Beside, a SG of 1.28-1.29 (PzS) means a more efficient conversion, which means more available energy using the same amount of lead plates.Last but not least, like you've pointed out, the PzS are cheaper (mass production).So, should I go with PzS for my off grid setup?
Lower SG means lower capacity for a given size battery, but (all else equal) likely longer life.
Personally, I'd go for the PzS if they're significantly cheaper, but the trade-offs are yours to assess.Off-grid.
Was looking into Hoppecke OPZS which were the recommended battery/cell for off grid, according to the distributor I was talking to, the price was 2.5 times that of GC batteries, perhaps they are more robust and better quality??
https://www.hoppecke.com/en/product/opzs/
liamg said:Still the OPzS are mainly recommended for telecomm use (mostly float) and their SG are usually around 1.24 (to avoid plate corrosion during extended float operation).Anyway, my question was: isn't the off grid operation more similar to a traction scenario (daily (deep) cycling)? Beside, a SG of 1.28-1.29 (PzS) means a more efficient conversion, which means more available energy using the same amount of lead plates.Last but not least, like you've pointed out, the PzS are cheaper (mass production).So, should I go with PzS for my off grid setup?
Initially, I thought that too but I have changed my mind.
After much research, I posted message #4, where I stated "The Electrical characteristics of OPzS & PzS batteries are identical".
Yes, the OPzS type is recommended for Telecom, but they are also recommended for all stationary float and deep cycle applications.
OPzS (stationary) means - do not install in a moving vehicle, ie Tow Motor, Electric Car, etc.
The OPzS (stationary) battery does have more electrolyte which helps with Long Term Float stationary applications.
But that, in no way, implies that OPzS is ONLY for Long Tern Float Applications.
I charge my batteries until they bubble (100% SOC & Equalize), so my electrolyte does get mixed.
The electrolyte in the PzS (motive) is constantly mixed due to the motion of the vehicle.
Supposedly, the PzS (motive) is designed "stronger" to handle the forces of motion ( not really important to us, unless you drop it ).
I would purchase the less expensive / more common PzS (motive) battery, even though we have a stationary application.
We gain nothing in a PV Solar application, by paying more, for the less common, OPzS battery.
You must bubble the electrolyte in the tall battery to mix the electrolyte since it is a stationary application or install a bubbler.
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
