Best Inverter/Controller location
Lumisol said:What's the thing in the diagram labeled inverter/controller then? Just a mislabeled controller?
JoeContiRC said:Thank you for that - but I am running a 100% 12v system. No inverter here
Then each wire has to be thick enough to have less than 2% voltage drop under max load. The cost of all that extra copper wire will likely be more than upgrading to an inverter to prevent the voltage loss problems. Sorry.
mike95490 said:JoeContiRC said:Thank you for that - but I am running a 100% 12v system. No inverter here
Then each wire has to be thick enough to have less than 2% voltage drop under max load. The cost of all that extra copper wire will likely be more than upgrading to an inverter to prevent the voltage loss problems. Sorry. -
Depending on the quality of the LED drivers, they may work ok. but you mentioned low voltages, did the light get low too ?
mike95490 said:Depending on the quality of the LED drivers, they may work ok. but you mentioned low voltages, did the light get low too ?
- 626 Discussion Forums/Café
