Winston LiFePO4 questions
liamg
Registered Users Posts: 43 ✭✭
Hello,
I have few questions regarding the Winston LiFEPO4 batteries.
(1) What's the difference betwen the "tall" and "wide" battery case variants? For example, they have two types of 100Ah cells with the following dimensions: 218x143x67 mm, weight: 3.3 kg (the "tall" one) and 218x179x62 mm, weight: 3.6 kg (the "wide" one).
For my aplication (off-grid solar system), the actual dimmensions doesn't matter, but is there any technological advantage of being tall (and slim) or being wide? Also, the "tall" one is lighter (3.3kg versus 3.6kg). Which one should be better? Does anyone know which one is representing a new (updated) product?
(2) They have a 12V pack (4 cells inside a box) which, according to the datasheet, are starting-up power battery for fuel cars. What does it means? I guess the cells were selected for higher discharge currents. Does it means the cells are overall better or there is a downside in regard to my application (off-grid energy storage)?
Any input is greatly appreciated!
I would definitely want access to each individual cell for balancing. Not sure you get that in a 12V pack.
They say the 12V box contains "finely balanced cells with identical perfomace" and "the battery must be managed as a single monolithic 12V block".They also describe a procedure to remove the lid to access the individual cells (using a knife and a hammer!). The box looks handy to me (as the cells are kept together using some metallic rods and aluminium plates on both sides).But how come they are so sure about the cells remaining balanced during the battery lifetime?
liamg said:They say the 12V box contains "finely balanced cells with identical perfomace" and "the battery must be managed as a single monolithic 12V block".They also describe a procedure to remove the lid to access the individual cells (using a knife and a hammer!). The box looks handy to me (as the cells are kept together using some metallic rods and aluminium plates on both sides).But how come they are so sure about the cells remaining balanced during the battery lifetime?
Random cells just picked off the line, and slapped together may differ quite a bit in both capacity and internal resistance. Battery bms that use simplistic bleeder techniques hide this fact. With reputable companies, one can usually specify that the cells they receive are finely matched, and even get a printout of performance - usually for an extra fee for those diy'ing it.
Thus, once top balanced, they stayed that way unless you abuse them. A very similar thing occurs with higher-quality motorcycle LFP starting batteries. Many don't include any bms. Some do, some don't.
By being managed as a single 12v monolithic block implies that simple two-terminal charing like a Pb battery would be sufficient. But of course, many users use the wrong chargers, wrong voltages etc.
If you want to treat it like a huge motorcycle starting battery (ie, the dreaded "drop in), one consumer type of charger you could apply would be a nice Tecmate-Optimate Lithium (LFP specific) charger. If you abuse it, this will bring it back and perform some modicum of balancing to a simple 4S battery. Not lab perfect, but good enough - at least in my own use.
liamg said:They say the 12V box contains "finely balanced cells with identical performance" ...
Do you have any proof what-so-ever that this actually occurs?
Is the warranty really only 1 Year? -
The warranty is 1 year, indeed, and they have another nasty terms: you have to pay all the shipping taxes to exchange a DOA product!Anyway, I guess I'll pass the LiFePO4 technology for now: seems like the NMC is the new "game changer" (though I bet it will be obsolete in a year or so).That's it, there's no chance to buy a really mature product these days (except for the grandpa's Pb batteries).
[duplicated]
mvas - The relative ease one can cut one open to gain access to the individual cells, and use even consumer hobby-type instruments to measure individual charge, capacity, and internal resistance makes *quality* manufacturers do this. Those that do might even be able to cross-reference their measurements against data sheets filed against the cells with serial #'s.
liamg - you won't get one "DOA" if you buy from a reputable seller / distributor. However, most battery manufacturers have shortened their warrantees knowing that many consumers purposely buy the wrong battery for their application hoping to play the warranty-scam to get free batteries for life, or at least several "free" ones. Either that, or they know that the average consumer just doesn't know the basics about LFP and is likely to kill it straight away.
Giveaways are the unwillingness to send back the old one first for evalution, having no proof of purchase, or inability to verify where the battery was purchased. Then when the manufacturer / distributor refuses to play this game, the owner bashes it online, usually without any reputable back-story about the application it was put into.
It's a game played with Pb batteries - most automotive boards are filled with this type of scam from a few members.
In your case, the "NMC" is an entirely different lithium chemistry than lifepo4, and charging LFP with NMC voltages will kill it. Hence the reluctance of many manufacturers to offer any warrantee at all to hobbies end users like ourselves who suspect that we are just going to wing it, kill it, and demand a refund or freebie.
PNjunction said:mvas - The relative ease one can cut one open to gain access to the individual cells, and use even consumer hobby-type instruments to measure individual charge, capacity, and internal resistance makes *quality* manufacturers do this. Those that do might even be able to cross-reference their measurements against data sheets filed against the cells with serial #'s.
What is WInston's definition of "Finely Balanced Cells".
Are you telling me that they sort the cells at the factory, and then assemble some battery packs with all higher-end capacity cells and some battery packs with all lower-end capacity cells? How is this higher-end capacity vs lower-end capacity actually labelled on each battery? Because I would prefer a battery with all higher-end capacity cells.
Until I see a definition and proof that the cells are "Finely Balanced", it is just Marketing Hype.
Oh wait, maybe they are "New & Improved" ...
jonr said:I would definitely want access to each individual cell for balancing. Not sure you get that in a 12V pack.
mvas said:PNjunction said:mvas - The relative ease one can cut one open to gain access to the individual cells, and use even consumer hobby-type instruments to measure individual charge, capacity, and internal resistance makes *quality* manufacturers do this. Those that do might even be able to cross-reference their measurements against data sheets filed against the cells with serial #'s.
When you buy a new car, there is no proof that you are buying anything worth owning so do you just never drive a car again? -
There was a time, some us of a certain age may remember it, when buying a car was almost as much of a crap shoot as buying "finely balanced" banks of batteries from China.Off-grid.
Learned a fair amount of car repair from my father as a very young kid... Much of it on the two day trips from SF to Phonies Arizona and back that we would take every spring break to see my grandfather--In a 1962 International Harvester Scout. Had a full tool box and roll of bailing wire to fix whatever broke (virtually every trip). That engine (literally 1/2 of a V8 designed four banger). Would do its best to shake off everything bolted to the engine (shatter the generator bracket bolts, toss of the throttle linkage, go through a wheel bearing or two, etc.).
And there was the older Jaguar that had a piston and rod that wanted out of the engine block really bad to visit San Bernardino.
New (after the Japanese "invasion" of reliable and not very expensive) cars are just so much more reliable (on average) than any of the old iron.
I remember my parents wrapping up a roast in a dozen layers of foil and putting it in a covered pot and strapping it to the engine on the way to Payson and having dinner cooked when we got there.
BTW, buying a car is still a crapshoot. -
I am responsible for two off grid systems that use Winston batteries that are around four years old. Total number of cells is 64. To date I haven't had any problem with any of the Winston cells although I have a question mark over maybe one cell in my system.
I can see why lithium ion battery manufacturers would be hesitant to give long warranties on the individual cells as they can be easily damaged if the final system that the cells are part of are is not designed, commissioned, and used properly. It should be a different matter if the battery is part of an integrated battery system with appropriate battery management and safety systems.
LiFePO4 (LFP) is not a fly by night technology. The first functional batteries were made in the 1990s. It has taken this long for the technology to be refined, tested and commercialised.
As far as I can see LFP batteries should have the edge over lithium technologies based around cobalt as they are safer and run at a lower cell voltage which implies that they should last longer. Having said this, the market for lithium cobalt based batteries is currently much larger than for LFP batteries so there has probably been much more work to extend the life of lithium cobalt based batteries.
Simon
Off-Grid with LFP (LiFePO4) battery, battery Installed April 2013
32x90Ah Winston cells 2p16s (48V), MPP Solar PIP5048MS 5kW Inverter/80A MPPT controller/60A charger, 1900W of Solar Panels
modified BMS based on TI bq769x0 cell monitors.
Homemade overall system monitoring and power management https://github.com/simat/BatteryMonitor
Giveaways are the unwillingness to send back the old one first for evalution, having no proof of purchase, or inability to verify where the battery was purchased. Then when the manufacturer / distributor refuses to play this game, the owner bashes it online, usually without any reputable back-story about the application it was put into.PNjunction said:
In your case, the "NMC" is an entirely different lithium chemistry than lifepo4, and charging LFP with NMC voltages will kill it. Hence the reluctance of many manufacturers to offer any warrantee at all to hobbies end users like ourselves who suspect that we are just going to wing it, kill it, and demand a refund or freebie.I wasn't talking about NMC as a direct LiFePO4 replacement, as I'm going to review my entire charging system anyway if/when I'm going to switch to a different battery chemistry. Regarding the "users killing their batteries" - that should be a valid point but I guess the vendor/manufacturer could distinguish between an abused battery and a DOA one. Couldn't they? -
karrak said:LiFePO4 (LFP) is not a fly by night technology. The first functional batteries were made in the 1990s. It has taken this long for the technology to be refined, tested and commercialised.That's why I thought of taking a break with my next purchase until this "chemistry war" it's over (will it ever?).
Lumisol said:jonr said:I would definitely want access to each individual cell for balancing. Not sure you get that in a 12V pack.
Are all of the Winston cells / batteries sold as unprotected?
It appears that there are multiple terminal connections for external BMS, on the batteries that have series connected cells.
I am waiting for a reply email from Winston. -
None of the Winston 12V battery blocks have any BMS included. Quote from the vendor product page:NOTE:Anyway, I guess none of the LiFePO4 cells came with the BMS included. Usually, a BMS is monitoring a large number of cells.
The monolithic 12V batteries do not have any PCM (any electronics) inside. They consist of finely balanced cells with identical perfomace. The battery must be managed as a single monolithic 12V block. -
Estragon said:There was a time, some us of a certain age may remember it, when buying a car was almost as much of a crap shoot as buying "finely balanced" banks of batteries from China.
liamg said:None of the Winston 12V battery blocks have any BMS included. Quote from the vendor product page:NOTE:Anyway, I guess none of the LiFePO4 cells came with the BMS included. Usually, a BMS is monitoring a large number of cells.
Very odd that Winston's website http://en.winston-battery.com/ has nothing on the subject.
Just learned that it may be called: BMS, PCM or, PCB.
BMS=Battery Management System (sometimes also 'monitoring')
PCM=Pulse Code Modulation
PCB=Printed Circuit Board -
As they apply to Lithium Ion Batteries ...
BMS = Battery Management System
PCM = Protection Circuit Module
PCB = Protection Circuit Board -
I think the former are more widely used than the latter.
Every occupation has its abbreviation--And, many times, they use the same TLA's from other disciplines. Perfectly valid, but can be confusing (TLA--Three Letter Acronym Top Level Assembly, are a couple variants I have used at work). TLA:
http://acronyms.thefreedictionary.com/TLATLAThree Letter Acronym TLA Three Letter Abbreviation TLA Texas Library Association TLA The Last Airbender (movie and TV series) TLA Text-Link-Ads (Internet advertising) TLA Top-Level Aggregation TLA Temporal Logic of Actions (logic system) TLA Tennessee Library Association TLA The Lost Age (game) TLA Theater of the Living Arts (Philadelphia, PA) TLA Temporary Lodging Allowance TLA Teaching, Learning and Assessment TLA Teacher Learning Academy (UK) TLA The Language Academy (Fort Lauderdale, FL) TLA Trial Lawyers Association TLA True Love Always TLA Transportation Lawyers Association TLA Total Laboratory Automation TLA Temporary Living Allowance TLA Thin Layer Activation TLA The Lawrence Arms (band) TLA Territorial Local Authorities (New Zealand) TLA Transformative Language Arts (Goddard College) TLA The Last Alliance TLA Top Level Architecture (information security defense-in-depth) TLA Timber License Agreement (Philippines) TLA Truth in Lending Act TLA Trinidad Lake Asphalt TLA Teller, Alaska (Airport Code) TLA Term Loan A TLA Three Letter Agency TLA Throttle Lever Angle TLA Top Level Assembly TLA Tournament Life Announcement (chess) TLA Two Letter Acronym (less common) TLA Top Level Aggregate TLA Training Level Assignment TLA Transluminal Angioplasty (navigating transluminally through blood vessels to perform angioplasty. TLA Terminal Lecteur Applicatif (French: Terminal Drive Application) TLA Temporary Lodging Assistance TLA Two-Location Algorithm TLA The Last Ambassadors (band) TLA Talk, Listen, Act (United Parcel Service training) TLA Telephone Line Adapter TLA Transmit Level Adjustment TLA Termination Liability Agreement TLA Toulouse Lalande-Aucamville (French rugby club) TLA True Life Anatomy Pty Ltd (software) TLA Triathlon du Lac d'Aiguebelette (French triathlon) TLA Time Line Analysis TLA Telemetry Link Adapter TLA Tenant Lease Agreement TLA Travel & Living Allowance TLA Total Living Allowance TLA Term Life Assurance TLA Teaching and Learning Assistant (education) TLA Terminal Low Altitude TLA Terminate and Leave Activated TLA Tie Line Class A (24 hours/day service) TLA Triple Letter Acronym (less common than Three Letter Acronym) TLA Techniques Loisirs Automobiles (French automobile service company) TLA Tissue-Like Assemblies TLA Theater Lead Agent (US DoD) TLA Transmitter Launch Amplitude TLA Talk-Listen-Action TLA Tamilnadu Library Association (India) TLA Top Level Alarm TLA Top-Level Administrator (computing) TLA The Latin Americanist (journal; Southeastern Council of Latin American Studies) TLA The Lost Art TLA Teaching and Learning Activities TLA Technology Licensing Agreement (contract) TLA Telstra Learning Academy (Australia) Why it is nice to spell out the Three Letter Acronym first and put in brackets (TLA) for the rest of the conversation.
Exactly, using an often otherwise used initialism, is just confusing and sometimes a lazy way of typing.
The PCB, PCM, TLA and BMS are all initialisms, not acronyms. An acronym is an initialism that is pronounceable, like NASA or NAFTA, an initialism is not pronounceable and is pronounced as the letters that make it up, like CIA and FBI.
- 616 Discussion Forums/Café
