Why bother reading instructions ?
mcgivor
Solar Expert Posts: 3,854 ✭✭✭✭✭✭
Was asked to help someone with a battery charger because the instructions were in english, more like engrish.
That's about as bad as it gets. Good thing instructions are the last resort for many of us.
I believe it is called Chinglish
OK, that example is funniest that I have seen!
The sad thing is I think I mostly understood the instructions.Off-grid.
Did you serve in the military deciphering enigma codes by any chance?Estragon said:The sad thing is I think I mostly understood the instructions.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Common sense will tell you what is intended even though the words are imprecise.
- 234 Forum & Website
