lost capacacity
Ok,
i went to check my battery's , and all seamed fine.
The charger was in float 13.7 volts 2 amps the sg was .275 .
I started to burn power ?
The battery's stayed up to 12.4/5 volts under load and bounced up to 12.6 in about 1 min .
In about 11/2 hrs I dropped down to 12.5 wats running the same equipment I had on last week that draped me to 12.3 in no time .
I will see how the batteries last over night , if there is good power in the morning i will run my smart charger on my batteries for the day at 6volts and charge 11/2 hr alternating from one to the other .
If things look not so good I'll take the battery's home and bench charge them .
I swapped out the mppt controler for a Morningstar sun saver l20
and after a few hours in the sun I'm blinking full charge .
I did give the mppt controler a good beating with a screw driver last week and had some lights flashing that really shouldn't have come on .
Maybe a sticky button jammed it up .
Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Sounds like swapping controllers solved the problem. Beating the offending controller may or may not fix it, but probably feels good!Off-grid.
If it does NOT start to charge, the next beating will start promptly at Noon next Saturday!
with a bigger hammer
You guys are Killen me .
Well last night I burned some power , ( average night ) at 1100 the battery's were down to 12.2 again ?
At 400am the voltage was up at 12.5? I figure 90% witch seems ok .
Why would I get a different type of reading .
Up till now my volts would drop slowly and if I un plugged the load the volts mite jump one point.
Now it's rebounding 3 points .
Any thoughts .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
How soon after getting to 12.2 V or ? and when did you take the reading.... ie were you A) watching it drop to 12.2V or did you unload the battery and
immediately take/get the 12.2 reading or did you C) wait a couple of hours before measuring? there is a big difference between A&B and C.... A and B are both essentially 'loaded' Voltage,.... C is the proper way to get the AT REST Voltage.... and at 4 AM that is why you got 12.5V after ~ 5 hrs of rest... had you done a series of B readings say each 1/2 hr you would have observed the rise in voltage .... the faster the rise the healthier the battery... hth
wellbuilt said:You guys are Killen me .
Any thoughts .1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I started with 12.7/8 at dark .
then used some power for 3/4 hours.
At that point I was at 12.2 I used 320 watt just guessing .
Turned off the load , and the voltage rebounded to 12.3
then I went to bed and at 400am I was at 12.5
incident look for 4 hoursOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
wellbuilt said:Ok,
I guess I'm just going to use the system and see if the battery get drawn down enough to turn off the inverter .
I've done every thing I know to do , I the batteries don't make the nighOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
I guess my battery's just have some age on them .
I added a morning star battery Monitor yesterday and it lookes nice for what it is.
Battery sg was looking above full charge today between 1.275 and 1300 all cells look the same .
The gadge dropped from 100% to 70% over 4 hour of lights inverter and tv plus phone charging (60 70 watts )
for 4 hours, Sooooo I'm thinking that I should be between 70/80 %
Then 7 hrs with my C-PAC sleeping and I still had 70% battery under load .
The battery bounce back to 80% in a about 2 mins unfortunately the sun popped out so I don't really know what the resting voltage ended up being .
I'm just going with it for nowOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
- 654 Solar Water Pumping
