Anyone done a DC pool pumping system?
solar_dave
Solar Expert Posts: 2,397 ✭✭✭✭
I am interested in removing my grid tie pool pumping system and adding a DC direct drive like the Lorentz system with a boost controlled and DC pump.
As a side question has anyone done a well pump direct off solar bypassing batteries... I would think a large storage tank could benefit from daylight pumping direct from solar.
Looks like the PS2 controller (system) should interface directly from solar array to their DC pumps nicely.
https://partnernet.lorentz.de/pdf/lorentz_ps2_product-brochure_en.pdf
The other way... Look for VFD controllers that take Solar PV input directly. And a pump+3 phase motor... Might be a bit cheaper (more research on your side).
Yeah I have been looking for such a beast in the 2-3 HP range AC. I think the problem is the buck boost required to start the motor at low input and the variability for the solar input.
- 230 Forum & Website
