Mini Wind Turbines
Does anyone know if any companies manufactures small wind turbines , that can be linked in series to produce 48V (10w-50w) .
The application would only be to power small electronics ( water pumps , charging small 6V / 12V batteries )
we are in hong kong and space is quite expensive here , it would be impossible to erect any larger wind turbines
Re: Mini Wind Turbines
Try these guys
http://www.copgoldtrading.com/southwestwind.htm
Good luck
Chuck -
Look on the store front also as NAWS does have these
http://store.solar-electric.com/wind.html
Chuck -
I think that you wanted to say in parallel not in series! I don't think that any turbine will work in series with another turbine, the AIR-X series for sure will mulfunction because it needs to be connected directly to the battery.
Brian -
yes, sorry ..
To clarify... A 12 volt wind turbine should be appropriate for a 12 volt battery bank.
A 48 VDC wind turbine can be difficult to get good power out of--Check the data sheets closely. One heavily promoted brand in the US starts generating 12 VDC at 6-10 mph... Its 48 VDC version seems to start generating at 20+ mph...
Wind turbines need a pretty windy area, clear of trees/building etc. and mounted pretty high in clear air. Plus, mounting them on the side of a building or roof can create a lot of noise issues--both from the wind/turbine in the air and from the sound being conducted down the pole/guy wires to the building.
If you can fit a solar panel (good sun, area to mount it), on average it will probably be better at supplying the power you need.
- 231 Forum & Website
