NWS Heating Element
HumMichael
HumMichael Registered Users Posts: 26 ✭✭
I have some extra panels and was looking at our host's dc heating element which are significantly expensive than other ones I can find.
I don't mind paying extra if I know why it costs more.
It will be just for pre-heating purpose before going into main water heater.
Anyone wants to share this brand experience?
I would like to stay 24 or 48v setup.
Sincerely
Michael
    You can get a high wattage element from a hardware store and use it at lower voltages/currents:
    http://www.homedepot.com/p/4500-Watt-240-Volt-Low-Watt-Density-Watt-Fold-Back-Screw-In-Stainless-Steel-Alloy-Water-Heater-Element-15011/204834493
    • P=I^R=V^2/R=V*I
    • R = V^2/P = 240v^2 / 4,500 watts = 12.8 Ohms
    • P = V^2/R = 24^2 / 12.8 Ohms = 45 Watts
    • P = V^2/R = 48^2 / 12.8 Ohms = 180 Watts
    If you can find higher rated power elements, you can figure out the actual heating at lower voltage.
    http://www.homedepot.com/s/water%20heater%20elements?NCNI-5
    Also, lower rated voltage / wattage (AC input) does not mean lower power at lower DC voltages:
    http://www.homedepot.com/p/1500-Watt-120-Volt-High-Watt-Density-Screw-In-Water-Heater-Element-15024/204834407
    • P at voltage = element rating at AC power * DC volts ^ 2 / AC volts ^2 = 1,500 Watts * 48v^2 / 120v^2 = 240 Watts
    One thing to watch for--The AC thermostats are not rated for full power at DC volts... It is very possible for a non-DC rated thermostat to burn out the contacts or even spot weld them together (short).
  • HumMichael
    Thanks Bill. I've done search function and have read other folks trying to do the same.
    I was just curious if our host's listing was much different than Hurricane solar guy's items.
    I am assuming that SSR is necessary when using "waste-not" auxillary function on my Midnite Classic.
    Sincerely
    Michael
    I don't work for NAWS, and I rarely talk with them (just details about the forum).
    I would guess that elements are Similar between vendors (and there are good and bad).
    Low volume stuff (solar only stuff) is going to be more expensive.
    If you have questions, please give our host a call. They have more information than I.
  • jonr
    edited March 2017 #5
    Maybe wire the thermostat (or any thermal switch) and the aux output in series and then to the input of a DC SSR.
  • HumMichael
    Bill, I certainly didn't think you had any affiliation with NWS.
    You have been a great moderator for a short time I have been on. Thank you.
    Sincerely
    Michael
    Michael,
    No problem... Sometimes new folks may not understand why I do not speak for NAWS. I don't work for them--I am just a volunteer here.
  • jonr
    I think Bill does a great job.
