Have Lithium Ion batteries come of age for off-grid systems?
13»
  • jimmyaz
    jimmyaz Registered Users Posts: 114 ✭✭
    edited February 2017 #62
    karrak said:
    jimmyaz said:
    With the LFP nowadays..... Which supplier is the trusted one?  Or do they even know what they are selling is quality battery or just another cheaply made one.   I'm not trying to be sarcastic, I am asking if I were to buy LFP, where would I buy it from if I am in North America?
    Voltronix http://voltronixusa.com/products/ is selling the Winston batteries under their name in the US, these are the batteries I use.
    Simon
    Thanks.
    Is your system 8cells of 3.2v to make up to 24v system?  So if I want 48V then best option is 16s?  Am I right that all of these LFP on the market are made in China?
    Dave Angelini Solar Expert Posts: 7,077 ✭✭✭✭✭✭
    South Korea is where mine are made. :)
  • jimmyaz
    Is that suppose to imply it's better?  Made by Samsung?  :smile:
    I know,. nowadays it's hard to find real quality stuff unless you got deep pocket.  I guess there's always risk in everything.  But I used to sell LiPo and deal with many Chinese supplier.... so I know what their quality is and there's no such thing as Quality Check.  :smiley:
    That is suppose to answer your question that not everything is made is China!
  • jimmyaz
    Then what cell are you using and where did you buy it from?  thanks
    Simon
    Simon, those appear to be LYP batteries not LFP
  • karrak
    karrak Solar Expert Posts: 326 ✭✭✭✭
    Yes you are correct, my system is 8 cells, 48V is 16 cells. I think that the majority of large prismatic format LFP cells are made in China. They are not as good as LFP cells made by A123 or other high end manufacturers but are just fine for off grid use.
    What are you thinking of using the battery for?
    Simon
    Off-Grid with LFP (LiFePO4) battery, battery Installed April 2013
    32x90Ah Winston cells 2p16s (48V), MPP Solar PIP5048MS 5kW Inverter/80A MPPT controller/60A charger, 1900W of Solar Panels
    modified BMS based on TI bq769x0 cell monitors.
    Homemade overall system monitoring and power management  https://github.com/simat/BatteryMonitor
  • karrak
    The Y stands for Yttrium. Winston puts small amounts of Yttrium in their LFP cells to supposedly improve their performance.
    Simon
    Simon
    Simon,  I think they are maybe fine for an advanced user like you but totally disagree that one would want anything short of the best offgrid. We are a small group living successfully offgrid. The transition from abundant power to lights out is something we just cant have and safety is right up there!
  • jimmyaz
    edited February 2017 #71
    I think I can understand why many of you suggest people to stay away from Lithium.  But teenagers driving and texting at the same time is dangerous too and really there's no way to stop it or "you" trying to avoid it, it's happening.  I have been using Lithium Polymer for 15 years in all my RC toys and they are not the puny little packs in these micro quadcopter, I am using 12-16s 10ah Lithium Polymer, 20ah packs for my big helicopters.  So I know what they are capable of and how they response to overcharge/discharge.
    Simon
    Currently my setup is completely independent and not tie to the grid.  But I have decided to install a Hybrid Inverter so I can run more load through out my house and the concept is to "Self Consumption and NOT feeding grid" all solar produce and maybe a small amount of battery usage during heavy load.  Obviously do not want to constantly use the battery, but I want to be able to use some so that when solar is over producing, it can store into the battery and turn around I will used it when needed.
    During winter time here in Arizona, my entire home only uses 11-15kw a day and during Summer time, 50-80kw a day.  My current array is 2.6kw.  Usable sun here in Winter = 5-6hours, Summer =7-8hours.  So I want to be able to offset as much as possible.
    There may be a problem, because all Hybrid Inverter running in AC support mode would require to pull the first 500watts from the Grid before it invert DC.  Everything in my house is super efficient therefor most of the time all the small load only pull 300-400 watts.  So it will not go over that threshold.
    Simon, I am waiting for more info to come back  from them, but here is what he had to say so far
    We have the LYP which is very similar to the LFP.  ....  What is your application?
     Brennan Patrick Beach
    CEO
    Voltronix
    ® USA, Inc.
  • Raj174
    edited February 2017 #73
    @ westbranch,
    LYP is a LFP cell that has the rare earth element yttrium added at the cathode to enhance charge and discharge of the battery at much lower temperatures. The specs indicate -45C.
    This is from an EV forum.
    default Re: whats the difference between lifepo4 and lifeypo4
    Hello Subevo,
    the main difference between lifepo4 and lifeypo4 is additional Yttrium at the cathode of the lifeypo4 cells to speed up electron transfer especially at cold temperatures. They are the better choice, especially for electric car usage. I received my cells in spring of last year, my car was one of the first conversions done with Yttrium cells. While driving through the whole last winter here in Germany I´m very surprised of these cells providing high amps at cold, freezing temperatures. I was able to drive my car at the coldest days. Without Yttrium this should not be possible regarding the experience of others. The voltage sag under freezing point is too much with the old cells. Yttriums sag a little bit, but you´re able to drive and receive the whole stored energy. Believe me, they´re really good.
    This is a link to the Winston battery specs. Notice the low charge and discharge temp and also extended life cycle.
    http://en.winston-battery.com/index.php/products/power-battery/item/wb-lyp200ahab?category_id=176
    Rick
  • karrak
    edited February 2017 #74
    How do you define "best", I would think "fit for purpose" is a more useful term. Sure, some people want an off-grid system where they can use as much power as they want regardless how much sunshine/wind/hydro there has been, don't want to be bothered with doing any monitoring and will have a nervous breakdown if they loose power. For them a very expensive, overspeced system with multiple backups maybe appropriate. The extra complexity in these systems can actually make them less reliable. There are others that are quite happy to have a simpler system and have some sort of contingency plan if they loose power. I have no backup generator and the lights/fridge have not gone off for the nearly four years that my LFP battery has been installed.
    There are well over ten DIY off-grid systems that I am aware of that use the cheaper Chinese prismatic batteries and not one has stopped working due to a battery failure.
    I totally agree that safety is a paramount consideration. IMO a simple off-grid system that is properly designed with a BMS of some sort that is being monitored and serviced on a regular basis by someone that understands the system could be safer than some complex branded "black box" which might have some engineering defects/shortcomings in it or might have been installed incorrectly or both. I suppose with the black box at least you have someone to sue if something does go wrong.
    Simon
  • karrak
    Have you looked at the economic and environmental costs and benefits of running a battery rather than just running a grid tied system?
    Simon
    edited February 2017 #76
    Simon
    I disagree because I own a business and as you say the users are all different but safety is a paramount choice I have to make for my clients.  The screen shot is at a minimum of what I want in highlite. I should be able to ID what I am testing very soon.
    Power is just power and there are many ways to make it happen. We go where the power lines don't!
    We agree on that part!
    Less is more is great also up to a point where the inverter power bridge shorts, a charge controller goes into runaway or a BMS defect . All of these devices need to be watched and not because of a law suit, in systems I am involved with. It is a heart beat to me.
    My choice right?
