trying to identify solar panel
westbranch
I fond a set of 4 Shell Solar panels on a gov auction site. there are no remaining identifying tags on the panels so trying to fiind them outside dimensions. they are 26 inches by 52 inches. Also a strange MC box arrangement.
link:
http://www.bcauction.ca/open.dll/showDisplayDocument?sessionID=9106540&disID=5426008&docType=Tender&dis_version_nos=0&doc_search_by=Tend&docTypeQual=TN
Any ideas? shell site only lists smaller or large dimensions, might they be old Seimens? cant find a cross link.
thansk
Eric
  • nigtomdaw
    nigtomdaw Solar Expert Posts: 705 ✭✭
    Re: trying to identify solar panel
    Eric the link didnt work for me came back as ...bad refer ?
    Nigel
    Thanks for the tip Nigel.
    Try this, it is the main page:
    http://www.bcauction.ca/open.dll/welcome
    haev to go to all Auctions (on the right hand) and at this time it is on the last page, ref num. A18924
    there are some other panels there also but I have been abele to get their specs...
    Eric
  • nigtomdaw
    Hows this for you had to resize it for forum
    If you see a picture on the web right click on it and copy it , paste 2 your PC then upload to the forum . I had to resize this but I use a free program that one of the experts on here reccommended called infraview its easy and brilliant for resizing photos. HTH
    thansk Nigel, I had tried to copy the pic of the panel rear view. and at first could not copy it. had an imbedded link. had to 'full size' it first then copy. Here is the rear, at bit different than I expecte d for a 12 v or 24 v arrangement..??5426008_Small2.jpg
    trying a tip Crewzer posted a few days ago..
    OK so it didn't work. I'll attach the image...
    Eric
  • crewzer
    Eric,
    I think they're Shell SM100's... here are links to info:
    http://pagesperso-orange.fr/nova-energies/cfdiffusion/sm100.pdf
    http://solarexpert.com/Shell/installation_US.pdf
    HTH,
    Jim / crewzer
    Thanks Jim, I think you are right on...
    they sure do look right. I figured they were more than the 80w versions I found. but definitely not the 160w version.
    I am going to make a bid on them now that I think I know.
    they are about 350 miles away...
    thanks again,
    Eric
    ps where/how did you find the info?
    ej
  • crewzer
    Based on the size info (26" x 52"), I guessed they were 100 W modules (~13 sq. ins/W). So, off to Google looking for "Shell solar 100 W". 8) The one's identified are 660 mm x 1316 mm, or 25.98 " x 51.81". Your pics with the unusual connection boxes helped as well! :cool: :cool:
    Regards,
    Jim / crewzer
  • nigtomdaw
    I think im getting better at this b4 Creezer answered with clarity my next suggestion was to try an efficiiency factor of 12 % and try using the 1000 watts to m2 rule, to work out the possible power. I would like someone like Jim to see how close this wold have worked, too much vino to try tonight from me. How close wold I have got Jim ?
    Nigel. 8)
  • crewzer
    Nigel,
    You're definitely on the right track: 0.66 m x 1.316 m x 1,000 W/M^2 x 12% = 104 W.
    Pour yourself another glass! ;)
    Now, where did I leave my glass of Friday night vino? :confused:
    Regards,
    Jim / crewzer
  • nigtomdaw
    Jim, Im smashed or chuffed 2 bits.......chufffed means happy
