Solar panel string charts
solarvic
Solar Expert Posts: 1,072 ✭✭✭✭
I have been trying to find a string chart for solar panels. Can anyone point me to a good one? Solarvic
Depending on the charge controller you're using, a reputable good name brand will have a string sizing tool on their Web site, which gives optimal panel arrangements, if this is what you're looking for. What CC do you have?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Thank you. I did find a couple good ones. Fronuis inverter and Morningstar.charge controller. I finally googled it.
- 234 Forum & Website
