Newish Big Buddy propane heater develops bad pilot light?
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
I've been using Big Buddy propane heaters for several years. Been good so I "splurged" and bought the larger model with two heat panels. 18,000 BTU instead of 9,000. It was nice...for approx. three months. (Bought it some time ago and can't return).
Yesterday the pilot light went out. This has happened before and was easy to relight. This time it wouldn't develop more than a small, weak pilot light with a pronounced yellow tip instead of the solid blue flame.
I reinstalled a smaller 9,000 BTU heater and it works fine. The problem is not in the tank or hose or filter. The thermocouple did not appear to be the very small and flexible copper line that might be expected. Though I looked at it very early in the morning and was not fully awake.
Big Buddies are often nice for off gridders due to no electrical needs while being efficient and "indoor safe".
Anybody with experience with this? Thought I'd try....
check for a spider web in the mixing tube area or just in front of the orifice... you need a pipe cleaner to get it out...
No pipe cleaners here. I fired up the compressor and blasted it from the front and underneath as well as trying to blast air into the propane intake. Works good now. Pat yourself on the back Westbranch!westbranch said:check for a spider web in the mixing tube area or just in front of the orifice... you need a pipe cleaner to get it out...
Funny in that everything looked real clean.
It doesn't take much to mess up the air mixture.
and those web filaments are almost invisible,,, Have to do the CSI thing with the flashlight and still can have trouble seeing them... Spiders love the smell of the added scent put in propane...
