All of the details of installation?
mstgkillr
mstgkillr Registered Users, Users Awaiting Email Confirmation Posts: 9 ✭✭
I'm considering a DIY 11.7 kW grid-connected PV install utilizing LG panels and microinverters unless someone suggests something else. Where do I find the code or specifics of the installation like how far the panels need to be from the edge or peak of the roof, disconnect requirements, etc...
Pictures of your installation would be great!
  • dennis461
    dennis461 Registered Users Posts: 109 ✭✭✭
    edited February 2017 #2
    I think a lot of those answers will depend on the state and local building codes, are you in NJ or AZ?
    Here in NJ, I had no restrictions on 'setback' from edge or peak.  Disconnects are NEC code dependent. Again, which version is your local building code using .
    Camden County, NJ, USA
    19 SW285 panels
    SE5000 inverter
    grid tied
  • mstgkillr
    Florida
  • mvas
    mvas Registered Users Posts: 395 ✭✭✭
    edited February 2017 #4
    Florida may still be using the older 2011 NEC.
    You need to find someone who knows the 2011 NEC as it pertains to Roof Mounted Solar PV and Grid Tie Inverters.
    Your local inspector's office may know and recommend a company with knowledge and experience.
    Do you need to submit plans to, and get approved by, the Electric Company?
    Do you have a NET meter?
    mstgkillr said:
    Florida
    Some areas of Florida require additional engineering report(?) of the roof structure. Check with local electrical inspector and power company.
    My brother had 2 emphase fail in Ohio. Both good and bad, they replaced the inverters, and provided some money toward their reinstallation, but nobody was interested in replacing them. I wrote a full accounting here;
    http://forum.solar-electric.com/discussion/351601/micro-inverters-reliabilty-and-manufacturer-recommendation
