will 6 inches cover the length ?
pyana1
pyana1 Solar Expert Posts: 39 ✭✭
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,172 ✭✭✭✭✭
    You want to use water miser caps, right?  Why don't you use the cable you have and just bend it in a "S" shape away from the caps? A straight short as possible interconnect isn't good as you should have some airspace between each battery.
  • pyana1
    edited February 2017 #3
    Exactly loll , the extented version.... guess i'lll just contort these to get a clear clearance  , thanks again !
  • pyana1
    edited February 2017 #4
    wish the Trojan hydrolinks were easy to find, i think i like them too... probably next year though, i give the misers a try for now, thanks again !
  • littleharbor2
    If they are still to long you could figure out how much you need to shorten them and cut them. Make sure you have proper lugs and crimper.
