Series wiring similar panels
S2T_Bama
Registered Users Posts: 8 ✭✭
Hi,
I bought a 160 watt Grape solar monocrystalline panel to go with my Tracer 20A MPPT controller. I had planned to expand to 480 watts by adding 2 more 160 grape panels. Unfortunately Grape isn't making those at the moment. I did find a good deal on panels with specs that look very similar to mine (see below). I plan to wire in series to reduce losses between panels and controller / battery bank. Can you folks tell me if it will be okay to wire these in series?
Grape GS-S-160-Fab8
160W
Voltage at Maximum Power Point Vmpp 18.5 V
Grape GS-S-160-Fab8
160W
Current at Maximum Power Point Impp 8.65 A
Open Circuit Voltage Voc 22.2 V
Short Circuit Current Isc 9.46 A
Everbright Solar 165 Watt
Voltage at Maximum Power Point Vmpp 18.10 V
Current at Maximum Power Point Impp 9.12 A
Open Circuit Voltage Voc 22.81 V
Short Circuit Current Isc 9.58 A
Thanks in advance for your help!
Shouldn't be a problem. Your 165 watt panels will loose about 1/2 amp of charging power each as they will be operating at the 160 watt panels Imp.
- 232 Forum & Website
