Can I do this?
Old Guy
Registered Users Posts: 51 ✭✭
I have my system running great now I think thanks to the members here......
I originally purchased 4 panels but 2 are working great.
I would like to use the other two panels for something. Are there any devices that can run directly from the panels with no controller?
I was thinking about a ceiling fan. They come in 120v AC for homes and 12V DC models for boats and RV's and I would be good with it just running when the sun was shining.
With a 120V AC fan, could I just connect a inverter to the panel and run 120 to the fan or would the fluctuating current not allow this?
Would this work with the DC fan without hurting anything? I got this idea from a small solar vent fan I have in the garage. Its just a small panel and fan but its been working great for years. It seems to be a regular 12V motor.
OR if anyone is running something straight from the panels or a panel/inverter setup I would like to hear about it.
If you can find a DC fan and drive it directly from the solar panels--That would be better. Note that DC brush motors do not last very long in continuous operation (brushes wear out in ~5,000 hours of operation or so).
There is a "black box" that goes between a solar panel and a small AC inverter--As near as I can tell, the black box has a voltage comparator and a relay. When the solar array voltage drops below ~10.5 volts, it turns off the AC inverter DC input to reset the low battery cutoff, to allow the inverter to restart. (most AC inverters "latch" the low battery voltage error and require a person to restart).
http://mwands.com/store/12-volt-suntaqe-pwb-inverter-controller
And a youtube video:
https://www.youtube.com/watch?v=kZ1BzbzdrGY
I make no claims about how well this will work for your needs or MW&S.
If it cheap enough for your needs--You don't have much to lose.
Seems like a fan with a brushless DC motor would be perfect.
You could add the 2 extra panels to your controller and use a small inverter to power the fan using excess power, what size are the panels, I forget.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Renogy 100 watt
You can add the extra 2 panels to your system and use a small inverter, say around 300W or less to power a ceiling fan whilst the sun is shining, it would be a simple addition, no need to look for special products, around $150 could get a reasonable pure sine wave inverte, Samlex are ok, check the host's store, don't get a modified sine wave, they will make the fan growl, not nice on a quiet day.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Thanks again Mcgivor.... I'm still trying to learn about inverters and how they can make 120 volts from 12. Its witchcraft I say!!! I just think thats awesome and I want to buy one and put some MONEY in it and see if it can multiply that as well.
Think of the inverter like a cashier making change. Two tens becomes four fives, but it's still twenty bucks ( less a commission in the case of an inverter). ☺Off-grid.
