Suitable controller
Bunghole
Registered Users Posts: 1 ✭
Hi I have three 130 watt PV panels connected to three 120 amp/hrs deep cell batteries using a basic 36amp controller (the 3rd one in about 2 years of use) the previous two ran the batteries down and this one seems to be doing the same. I am connected via a 2000 watt pure sine wave inverter and mainly run a small circulation pump and a number of 240v LED lights in my seldom used off grid cabin. Can anyone advise me on which controller I should use for this system. Cheers.
Welcome to the forum... Can you tell us a bit about your system?
Roughly, where is it located (UK/Ireland?)
Do you run the inverter when you are not there?
A 2,000 Watt AC inverter is pretty big for a 360 AH @ 12 volt (?) battery bank. Closer to a 1,000 - 1,500 Watt AC inverter would be about the maximum for that size battery bank. And if you can get to a much smaller AC inverter (like 300 Watts).
And, depending on where you are at--Say Dublin--You may not get much sun:
http://www.solarelectricityhandbook.com/solar-irradiance.htmlDublin
Measured in kWh/m2/day onto a solar panel set at a 37° angle from vertical:
So--This time of year--Dublin gets about 1 hour of sun per day (January) average. An off grid power system with 390 Watts of solar would generate:Jan Feb Mar Apr May Jun 1.08
1.79
2.48
3.42
3.91
3.76
Jul Aug Sep Oct Nov Dec 3.70
3.42
2.93
2.06
1.42
0.94
- 390 Watts solar * 0.52 off grid system eff * 1.06 hours of sun (Jan) = 215 Watt*Hours per average January day
- 20 Watts Tare load (Inverter) * 24 hours per day = 480 Watt*Hour per day
- 230 Forum & Website
