enphase m-250
willchilite
Registered Users Posts: 4 ✭
Have a grid tie system and I was working on the system on Saturday , turned off the main power and noticed after I had turned the power back on a day or two when I went to the internet to check on my energy production that my micro inverters were not communicating with the envoy receiver, tried everything I could to bring it back up but still not communicating if anyone knows something about this can you please give me some advise on what to do thanks in advance.
This is probably the best source for information regarding your problem.
https://enphase.com/en-us/support/system-owners
I had an odd occurance with my system a week or two ago. Full sun, cold, only showing 1/3 of expected production. The reporting was not correct...the same production from each inverter for 3 hours? Not likely. Finally unplugged the envoy for a few minutes. When it powered up again everything was back to normal. Maybe you just need to turn it off and on again (the IT guy's best weapon).
Ralph -
well I go to support system and I cant find the answer there then they tell me to get in contact with the installer the warranty is over so I'm stuck without finding the answer
i also tried to turn it on and off but that does not work
sorry off then on
Well that's not much help, a company should still offer support IMO,1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 228 Forum & Website
- 618 Discussion Forums/Café
