100 watt solar panels
DConlyGuy
DConlyGuy Registered Users Posts: 80 ✭✭
3 of the 4 panels i have have these lines in them, they seem to be working like always but i wondering iof these are all defective or not3 of
600 watts of solar panels,Epever 30 mppt , 2 PWHR12500W4FR battery's in 24 volt setup
    BB. Super Moderators, Administrators Posts: 33,703 admin
    You can search for the term "snail trail" -- Generally not a problem (as far as I know):
    http://www.onlinetes.com/article/tes0512-solar-industry-snail-trail/
    If you see physical cracks/browning--Those are failing (ed) cells and would need the panel replaced.
  • DConlyGuy
    thanks bill i was reading a post over on other forum and sunking said it was junk, so i just wanted to make sure.  i did test them all and all of them were putting out 20 volts each. it seems to be happening to a lot  of the 100 watt panels, my renogy panel does not have them yet, but it ia 6 months newer than the others so ill wait and see if they develope them too
    You have to check/monitor Isc/Imp too... Voltage only check is not good enough to catch poor/broken electrical connections/cells.
  • DConlyGuy
    they hit 20 amps today in bulk that is what they have been hitting for last year ive had them
    snail trails are wavy lines, those have lots of straight components that look like cracking.  I think they are going to fail you come a couple hot days and they start getting brown edges
