Inverter Power Save Mode
There is the parallel load of the pump and controller, at just under the set point of inverter powersave
I had a similar problem in that my water pump would overload the inverter if it tried to start while the inverter was in standby mode. So I cobbled up a second pressure switch set to a slightly higher tripping point that when activated, turned on a night light bulb. Eventually replaced the substandard motor with a high efficiency Leeson 1/4 hp and never needed the second pressure switch and load.
But now, with the price of solar so low, why not just leave the inverter running 24/7? That's what I'm doing now.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
