12v solar to 24v batteries
joel
joel Registered Users Posts: 4
I have 2 x 100w solar panels, 2 x 12v 100ah batteries and a 12/24v 30amp controller(EPEVER model Es3024a) can I make this into a 24v system?
    yes, likely.
    You would put the batteries in series for 24 volts. and use 12 volt nominal panels in series for a 24 volt nominal array...
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,157 ✭✭✭✭✭
    Needed to check model number. Is this a VS 3024A? if it is then yes you can do 24 volts. Epever has mppt controllers in their lineup and if it were an mppt controller then the answer would be you would need at least one more panel to raise the input voltage high enough above the battery  voltage for the mppt to do it's thing.
    What are the exact specs on those panels? If Vmp is > 17V they will work fine if in series.
  • joel
    Yes littleharbor VS3024A how do I connect solar panels in series?
     2- Solar Panel 100W Polycrystalline 12VDC 1- PWM 30A Solar charge controller with LCD screen to regulate voltage between the solar panel and the battery(s).-Model: WP3024Z -System voltage: 12V/24V Auto -Dimension: 187mm x 98.5mm x 49.5mm -Weight : 400g Solar Input: -System voltage: 800W (12V) / 2000W (24V) -Solar input voltage: <50V -Rated input current: 30A Battery: -Battery type: Sealed, GEL, Flooded and User -Charging mode: 4 Stage (Bulk, Absorption, Float, Equalizing), PWM-Float voltage: 13.7V (13V~15V) x1/x2/x4-Absorption voltage: 14.4V (13V~15V) x1/x2/ 2- 12 AWG Solar cables to connect the solar panel to the charge controller, each of 20Ft long with MC4 Connectors 2- 12 AWG Solar cables to connect the controller to the batteries. Each cable is 7Ft long and comes along with alligator clamps for easier setup between the charge controller and the batteries. Type: SEDC-100W 1) Cell Type: Polycrystaline (A Class) 2) Voltage: 12 VDC 3) Dimension: 50*28*1 in 4) Rated power (Pmax): 100W (+/- 3%) 5) Open Circuit Voltage (Voc): 22.54V 6) Short Circuit Current (Isc): 5.64A 7) Max Power Voltage (Vmp): 18.72V 8) Max Power Current (Imp): 5.35A 9) Solar Panel Grade: A 10) Nominal Operating Cett Temperature: -40 to +85C 11) Maximum System Voltage: 750VDC 12)
    BB. Super Moderators, Administrators Posts: 33,703 admin
    Here is a nice explanation of series/parallel:
    http://hespv.ca/blog/wire-solar-panels-parallel-vs-series/
  • littleharbor2
    Out to controller+       -+   - out to controller.
    Assuming you have polarized connecters on your panels you will plug the positive lead from panel #1 into the Negative lead from panel #2. Now you have a positive and negative lead hanging free. these connect to your charge controller.
  • joel
    Cool guys, thank you so much, it's all connected and working fine.
    Now I have another Question: what would be the less drain on batteries? 12v 24v or install a converter and run 110w? I'm running a Whynter 62QT dual zone fridge/freezer.
  • Estragon
    12v may be a bit more efficient (assuming short cable), but if you're set up for 24v I would use that. Inverting to 120v should be less efficient than either dc voltage.
  • Estragon
    Also, I hope you have a generator or other means of charging batteries for low sun days. The fridge will drain those batteries pretty quickly and you don't want to drain them to much less than 50% full.
  • joel
    It's been pretty good so far on 12v the solar panels have been keeping up, on cloudy days I turn the frige off occasionally, but I read that it would be less of a power drain on the batteries at start up on 24v so I'm trying that, it's using 2amp while running. I was thinking of installing a timer to minimize usage, I don't think it needs to run as much as it does.
