Midnite solar meter
DConlyGuy
DConlyGuy Registered Users Posts: 80 ✭✭
for last 8 or so months, been thinking my battery's were off for some reason. now i found out why. bought one of those midnite solar meters and the darn thing says im down to 60% most nights before i shut down for the night. for some reason never looked at a chart for battery state of charge chart,just belived the meter and bang there it is, my battery's never go below the 90% mark on all the charts ive seen  asmy battery voltage very rarely go below 12.5 on any other meter i have. From now on im just  gonna  use the meter that goes with my charge controller and stick with it. just gonna chalk it up to  55$ loss
600 watts of solar panels,Epever 30 mppt , 2 PWHR12500W4FR battery's in 24 volt setup
    The Midnite BCM battery monitor is a voltage based monitor. Voltage based battery monitors are NOT a good method of determining the State of Charge (SOC). This would include checking the voltage at any point in the system for the same information. When you are shutting down your system for the night, it likely has loads running or recently run and not at rest. It might do you some good to first check to be sure the monitor is setup correctly and then check the voltage at the monitor when you are about to shut down.
    I don't know how you have the monitor wired or setup, but likely the Midnite should be in the ballpark at the monitor. If you are checking the voltage at the battery, understand that this is NOT the voltage that the monitor is seeing.
  • Vic
    Hi DC..,
    The MNBCM  monitors how long since the battery has received a full-charge,  and from that point,  is uses only battery voltage,  which is not compensated (by measuring actual battery temperature with a  BTS):
    http://www.midnitesolar.com/pdfs/batCapMeter_frontBack.pdf
    So,  there will be the temperature effects on battery voltage,  causing inaccuracy,  AND  the inaccuracy of measuring battery voltage of a battery that has not been Rested (Resting is when a battery has not received any charge or discharge for many hours,  like 12 hours).
    Voltage is generally not an accurate indication of State Of Charge (SOC) of a battery.
    If your 235 Ah batteries are Flooded,   SG measurements are the Gold Standard of battery SOC.
    Vic
  • DConlyGuy
    edited November 2016 #4
    the battery and the monitor and charge controller all with a foot of each other and they are inside the house so no big temp swings. i knew it was just a voltage measuring thing but im still sitting at 12,54 volts at 10 pm and darn thing saying i used 40%, i just think i got a defected one and didnt know it.
    What are you using to measure the voltage? just the charge controller?
    Did you setup the jumper on the monitor for your battery type?
    Midnite is pretty good about replacing or helping people, have you contacted them or posted on their forum?
  • DConlyGuy
    checked voltage with charge controllers monitor it victron blue stuff and a regular volt/ohm meter ,yes jumper for 12 volt was on and the jumper for battery type was off for fla battery's as it should be
    Midnite forum;
    http://kb1uas.com/mnsforum/index.php?PHPSESSID=02e3232812c9935674cf2fc388a9dd2b&
    Midnite Support;
    http://www.midnitesolar.com/support.php
