Is this normal for a BMK
pyintheye
Registered Users Posts: 35 ✭✭
Hi to all
The charging amp values from the BMK read out on the Remote are not in sync with the Magnum, Inverter amps screen. There seems to be a greater discrepancy as the battery voltage increases. At absorb voltage there is a 3.5-4 amp difference, and up to a 7 amp spread when I am equalizing. Can anyone tell me what screen I can really believe or If I may have an issue to correct.
Midnite Panel Box for MS4448PAE, FM60- 720w, FM80- 2340w, 8 Trojan L16H AC- 48V, NH600 Turbine, DHW 2000w opp/div load.
Is the Magnum Inverter the only charging source/load when you are testing the BMK Battery Monitor?
If you do not have one yet, a DC Current Clamp Meter is very handy for answering these questions... Sears sells an AC/DC Current Clamp DMM that is "good enough" for our needs. (note: normally $60--But currently on sale for $45 at the time of this post Nov 16, 2016).
BB. said:Is the Magnum Inverter the only charging source/load when you are testing the BMK Battery Monitor?
I didn't think to check it with the Clamp Meter. I was just wondering if it was normal for the 2 readouts to be out of sync or if this is just a Magnum software programing glitch. Any other suggestions/ observations from other posts?
Midnite Panel Box for MS4448PAE, FM60- 720w, FM80- 2340w, 8 Trojan L16H AC- 48V, NH600 Turbine, DHW 2000w opp/div load. -
You'd better trust your BMK meter display only. If correctly mounted, in/out current to your batteries is pretty accurate.
A+
Erik
Just did the clamp meter test and the BMK readout is the winner.
Thanks All.
Yes, inverters are designed to turn DC into AC power. Logging and measurements do not need to be very accurate. A precision resistor costs a fair amount 6 of money and space which is not used by many inverter customers.
- 228 Forum & Website
- 653 Solar Water Pumping
- 618 Discussion Forums/Café
