Guide for wire sizing from charge controller to battery bank?
softdown
softdown Solar Expert Posts: 4,034 ✭✭✭✭
Ideas?
I could probably look this up. Like food, fresh is better?
  • softdown
    edited October 2016 #3
    Am downloading a free 134 mb program that should open that calculator. I use a bunch of old, cheap computers for reasons unknown.
    http://www.openoffice.org/        This worked fairly well....except for "chopping off" the numbers for line loss.
    Thought I seen an easy chart in a solar book...once upon a time.
  • Wheelman55
    Wheelman55 Registered Users Posts: 255 ✭✭✭
    Southwire has mobile apps for voltage drop and conduit fill.  Once on your smartphone or tablet they don't need an internet connection.
    Off-Grid in Terlingua, TX
    5,000 watt array - 14 CS 370 watt modules. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
  • softdown
    Thanks! Using these numbers:
    Voltage.................40
    volts
    Maximum voltage drop...................3 %
    Typically, 3% or less is the recommended level for efficient operation of equipment.
    Length of cable run.................16 feet
    Current at the end of cable run......................16 amps
    Yielded this:
    Results
    1 conductors per phase utilizing a #12 Copper conductor will limit the voltage drop to 2.23% or less when supplying 16.0 amps for 16 feet on a 40 volt system.
    For Engineering Information Only:
    20.0 Amps Rated ampacity of selected conductor
    1.9029 Ohms Resistance (Ohms per 1000 feet)
    0.054 Ohms Reactance (Ohms per 1000 feet)
    1.2000000000000002 volts maximum allowable voltage drop at 3%
    0.889. Actual voltage drop loss at 2.23% for the circuit
    0.9 Power Factor
    I was inputting data for the final run from the combiner box to the charge controller. Guess I didn't need to install the 8awg yesterday after all.
    Also feel like I failed to account for one or two things.
  • Wheelman55
    edited October 2016 #6
    Looking on the bright side you'll have less than 1% voltage drop using the 8 awg.
  • Wheelman55
    edited October 2016 #7
    Also got a box fill app from: snappyapz.
    http://snappyappz.com/
  • softdown
    Apparently...yes. Sure didn't make a difference in my overnight battery voltage. Seems like batteries like to sit at ~12.5 volts with minimal drains ... unless charged within the past few hours.
